Question about Microwave Ovens
Sm12sl microwave proline - Microwave Ovens
Proline microwave 3535T sound not working
Your question is not really quite clear. What kind of sound is supposed to produce a microwave oven?
It works or not? Heats or not?
If it won'r work take it to repair to s qualified microvawe repair tech.
Jun 18, 2015 | Microwave Ovens
How to use Proline MicroChef ST235?Can i use it for baking?
Hello...
BAking is not recommended in microwave.
is not recommended because the excess of humidity blasting circuits and metals.
Aug 10, 2014 | Microwave Ovens
Proline 850 Watts Microwave Oven Door release does not open the door. Model 3535T May1993 Made in Korea. There's no resistance when I try to open the microwave door by pressing the door release push. As...
This has actually happened to other people? When this happened to me I was shocked, I've never in all my years have ever dealt with something like this. I had tried to fix it for a good two weeks. I had to break down and call in some <a href="http://www.doorsystems.com">door systems in Chicago</a>, to help out. I hate fixing doors. I have the worst luck with them.
Mar 29, 2011 | Microwave Ovens
Proline Micro Chef ST 22 User Manual
google mauritron who may have it
Feb 21, 2011 | Microwave Ovens
I need to replace a broken door hinge on a Proline washing machine reference number: WMP - 1120 V. The machine was made in France but it is a Comet product and is sold in Comet's stores in the UK. I am...
Hi Tony , sorry its not much of a solution but try partsmaster , i'll post the link to there inquiry form ( ive used it many times before and whilst there a bit pricey there usually very good ).
http://www.partmaster.co.uk/cgi-bin/pne.pl?display=entry&brand_id=3346&f-10=
Aug 08, 2010 | Microwave Ovens
Instruction Manual Needed
The only ref online is http://www.espares.co.uk/parts/microwaves/proline/micro-chef-st22/p/1095/1169/0/542092
Any microwave cooking guide should walk you thru the steps
Jul 28, 2009 | Microwave Ovens
Spare parts search ProlineST44 Microwave
your after what i call in australia, is a high voltage fuse, readily availableeither online or from any electronics spares dealers.
Jul 06, 2009 | Sharp R-242 Microwave Oven
My proline st44 microwave just suddenly went dead. I?ve checked and changed all fuses on the microwave and leads. It comes back again and then goes dead again. The inside door mechanism seems to be intact...
ProLine ST44 950 Watts Microwave
Since this machine is only sold in the UK I do not have a picture to point you to.
The problem is probably a blown thermal fuse. This fuse is located inside the machine and is for detecting overheating and fires. Sometimes age will cause it to fail. It's generally located near the air vent outlet.
If you handy with fixing gadgets you can check it.
Unplug the machine and remove the cover.
You can take an ohmmeter and test it. If it shows open you can replace it. It may be soldered in I am not sure. You can get replacements at an appliance parts store or Radio Shack®. There may be conventional fuses inside so you can check them also.
If nothing else is wrong it might be a door switch problem.
Wear on the interlock causing the crowbar microswitch to short the line and blow
the internal line fuse. The interlock, required by law, contains 3
switches - one switch sends a door-open signal to the
microprocessor, one opens the line and the third crowbars (shorts)
the power leads to the magnetron. If the crowbar switch activates
before the line switch opens, the line fuse gets blown. Just toss the crowbar switch.
May 12, 2009 | Sharp R-242 Microwave Oven
Proline M-2020 microwave manual needed
Do you still want this - I have a paper copy which I no longer need
Mar 27, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
