Question about Hardware & Accessories
Honeywell Manuals Honeywell Pressuretrol, PA404A1033, Steam pressure control
2 Suggested Answers
burzerko
  • 254 Answers
SOURCE: my boiler most of the
Looks as if your boiler is over firing (extended run) you probably have a faulty sensing thermostatic probe causing this the switch you are resetting is a safty pressure switch it is designed to keep the pressure from building which could cause the boiler to explode.
Posted on Nov 15, 2008
I have a 220v pressuretrol connected to my well pump. Also connected was a 220v chlorine injection pump. Recently the pump cratered, had a teck install a new pump, however it is 110V, he changed the wiring...
The 220VAC is most efficient and less costly in the long run. You should not have changed over. Got back to what was working for you in the past!
Jan 04, 2015 | Dryers
Lochinvar DVN051 Water heater, I checked voltage on transformer, fine, checked pressure seitch, fine, blower runs fine, gas is on and stat clicks when I rotate it and kicks the blower os, I checked th
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also: Scroll up on same page for Pressure Switch heading.
Lochivar is made by Bradford White I believe.
Same troubleshoot page has link to Bradford White service manuals, and service manuals posted by AO Smith, in case this product is through one of their subsidiaries.
Rheem does not make this product, good thing for you because Rheem doesn't post service manuals.
Sep 09, 2012 | Honeywell Water Heaters
How do l replace the electronic gas control valve on a whirlpool hot water heater tank?
Whirlpool is made by American water heater.
Gas valve is made by Honeywell.
Whirlpool electronic control is version of Honeywell 'Icon' gas valve: There are several versions of this gas valve.
http://waterheatertimer.org/pdf/Bradford-White-service-manual.pdf
Start page 24 shows: Testing, disassembly and replacement of typical Honeywell gas valve.
Whirlpool phone number 1-877-817-6750
Whirlpool manuals:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
Aug 10, 2011 | Whirlpool Water Heaters
Fissler Pressure cooker has steam coming out from the Utimax valve, is this normal?
Hi. Some steam is ok. But when it is running it should be sealed up. The little rocker should be doing it's thing too. Good luck.
Jul 25, 2011 | Microwave Ovens
I JUST INSTALLED HONEYWELL TH6110D1021 THERMOSTAT FOR A STEAM ZONE VALVE. I SET THE THERMOSTAT FUNCTION BY PRESSING THE UP ARROW AND FAN BUTTON. THEN CHANGING THE RIGHT NUMBER TO 2. NOW I WANT TO CHANGE...
Hi and welcome to FixYa. I am Kelly.
Suprizingly enough there is an abundance of manuals for your Honeywell Programmable Thermostat. Use this link and at the bottom of the page you can download any of the manuals.
http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1021
Just note that pop ups must be enabled to download the manuals
Printable Quick Reference Sheet (after download)
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1778ES.pdf
Thanks for choosing FixYa,
Kellly
Oct 15, 2010 | Honeywell Programmable Thermostat Heater
Hhow to set the pressuretrol??
I assume you are talking about a steam heating system...
There are two screws on the top of the pressuretrol...
turn the pressure screw down to the lowest pressure at which you still get heat to the farthermost radiator...make sure the vents are working...or steam does not flow to displace the air...
Then just give the differential screw enough difference so the boiler cycles on and of a bout three times and hour...when making steam...
That's all there is too it...
heatman101
Oct 08, 2010 | Heating & Cooling
I have a honeywell PA404A pressure control switch on my home gas steam heating system. I'm having a problem with the switch turning off the system. It will only come back on if I turn the top screw all the...
This may be caused by accumulation of sludge in the steam trap (the looped tube that connects the pressuretrol unit to the boiler). the sludge restricts the pressure from reaching the diaphragm in the pressuretrol unit. So it gets a false reading. Clean or replace the tube and see if normal function resumes.
Jan 06, 2009 | Heating & Cooling
My boiler most of the time don't star until I push the switch in the pressuretrol (honeywell) PA404A1033. After I activate the turn on and off regular for some hours but later again don't star until I...
Nov 12, 2008 | Honeywell Heating & Cooling
Hardware & Accessories Logo
42 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
