Question about Zanussi Dishwashers
Zanussi zds2010 dishwasher will not drain - Zanussi Dishwashers
My zanussi dishwasher zdt12011fa will not switch off and the pump continues to run, obviously trying to remove non existant water! any ideas??
Most dishwashers (especially built in dw) in the bottom has microswitch which is activated if water leaks and runs drain pump to prevent flooding.
Dado
Feb 08, 2015 | Zanussi Dishwashers
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Got a zanussi dishwasher zsf6160, lights working but none of the programmes are starting, not taking in any water?
if you can here the drain pump run at the start the fault is with the water valve or blockage in the side tank on the lh side. if you dont here the drain pump it possibly the heater thats down to earth. the electronics can detact it and not start the prog if heater faulty.
Jul 22, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
Zanussi ZT685
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Dec 21, 2007 | Zanussi ZT485 Built-in Dishwasher
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
