Question about Cell Phones
Someone changed my philibao-5688 model pin code i tried 0000 but it did not unlock.
2 Suggested Answers
dreyont
SOURCE: lg Scoop unlock code
did you dial ##3282# or ##3282##? dial the second one i said. then if it ask for
Posted on Aug 13, 2009
Codes for the sims
Most phone companies will use 0000 or 1234 as default sim pin codes. If its neither of these then it may be possible the sim pin has been changed. Usually if you enter the wrong pin to many times your phone will be locked and you will need to get a puk unlocking code from your service provider. Once you have entered the puk code your phone should give you a option to change the sim pin code
Aug 01, 2014 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Tip
Default Pin & Security Codes for SIM cards
A number of networks still use a default pin on their SIM cards at the point of dispatch as a security precaution. If you lose or forget the PIN code it can be irritating.
Please note these PIN's will only work if you have NOT changed the default PIN. If you enter the PIN code incorrectly three times, a lock will be put onto the SIM card, and you need a PUK code to unlock it.
You can obtain your PUK by contacting your network service provider.
Default Network PIN Codes:
O2 = 0000/4321
Orange = 1111
Vodafone = 0000
Fresh = 1210
Virgin Mobile = 7890 / 1210
Vodafone = 0000
Talkmobile = 0000
3 = 0000
on Dec 23, 2009 | Cell Phones
Locked out of thermostate
From the manual:
PROGRAMMABLE KEYPAD LOCK
To prevent tampering with any of your settings or
temperatures, the front panel buttons and the rotary dial can
be locked out, requiring a four digit code to unlock them.
You may use either the default lock code of "0000", or your
own personal number combination (see "Changing The Lock
Code")
LOCKING THE THERMOSTAT: Ensure the rotary dial is in the
RUN position. Press the NEXT button for at least 2 seconds.
The words "ENTER CODE" will appear on the screen, along
with "0000". Press the NEXT button again for at least 2
seconds. A padlock should appear on the screen to confirm
that the thermostat is now locked.
UNLOCKING THE THERMOSTAT: Ensure the rotary dial is in
the RUN position. A single press of any button should cause
the words "ENTER CODE" to appear on the screen, along
with "0000". If the default code was used to lock the
thermostat, press the NEXT button for at least 2 seconds.
The padlock should disappear from the screen, and the
thermostat should now be unlocked.
If you try to unlock the thermostat by entering a code that is
not correct, a padlock and the digits "88:88" will flash on the
screen and you will have to try again. If a lock code
different from the default was used, this will need to be
entered by using the UP/DOWN buttons, and the NEXT
button to advance to the next digit. Once the correct code is
entered, press the NEXT button for at least 2 seconds and
the thermostat should now be unlocked.
CHANGING THE LOCK CODE: To create your own specific
lock code, first ensure that the rotary dial is in the RUN
position. Press the NEXT button for at least 2 seconds. The
words "ENTER CODE" will appear on the screen, along with
"0000". Now press the HOLD button again for at least 2
seconds. The words "SET CODE" will appear on the screen,
along with "0000".
IF YOU FORGOT YOUR LOCK CODE: You can still unlock the
thermostat by performing the following steps: On the back
of thermostat locate JP1, which is a row of 3 metal pins at
the right edge of the circuit board above the battery tray.
There should be a plastic jumper cap on 2 of the 3 pins
(right or left).
Move the jumper cap so that it is on the opposite 2 pins.
For this change to be recognized, move the Temperature
Mode switch to any other position than its current one.
These steps listed should have changed the lock code back
to the default of "0000". Follow the instructions already
listed in "UNLOCKING THE THERMOSTAT".
Sep 02, 2012 | Lux Tx9100e 7 Day Universal Programmable...
Unlock pin code nokia required for model 1661 2 I have forgotten my pin code please can you help thanks
Hi
The default PIN code is 0000.
If you changed it and forgot the PIN code please contact your service provider. They will provide you the default PIN code so that you can use your phone.
While you get the PIN code, service provider will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PIN code
This PIN code is FREE. You no need to pay any sum to get the PIN code
Thank You
Feb 25, 2011 | Cell Phones
How do you master reset a gravity touch
If your Samsung Gravity T (T669) is stuck on the PIN lock screen and you do not have the code to unlock, you can try a master unlock code... 73683139 to override and then go to settings and turn off lock feature. When you reactivate lock feature it will prompt you to select a new PIN.
If your phone requires the T-mobile PUK code to unlock (you get a message that says call support PIN is locked) the PUK unlock for this phone is **05*22998214*0000*0000#. This will unlock device and reset PIN to 0000.
Enjoy.
Jan 24, 2011 | Samsung Gravity Touch T669
Hs850 pin code
The pairing PIN code should be 4 zeros: 0000
Jan 18, 2008 | Motorola Mobility HS850 Consumer Headset
LG CU400
Locking and Unlocking the Device: FOR LG CU 400
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Lock Handset.
  5. Select desired option:
    • When Power On
    • When Smartchip Changed
    • Immediately
    • Off
  6. Enter the Security Code, press OK.
    NOTE: The default security code is 0000.
Setting the PIN Code:
  3. Scroll to and select PIN Code Request.
  4. Scroll to and select On.
  5. Enter the PIN code, press OK.
    NOTE: Default PIN code is 1111.
Changing the Security Code:
  3. Scroll to and select Change Codes.
  4. Scroll to and select Security Code.
  5. Enter the current Security Code, press OK.
  6. Enter in the New security code, press OK.
  7. Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
Nov 28, 2007 | LG CU400 Cellular Phone
Pin code
set up your phone to search for BT devices, press and hold the phone button on your Skywing or H700, once the purple light comes on open the boom. Your phone should see the device. When prompted for a passcode enter 4 zeros, if that doesn't work, try 5 zeros, if still no luck try 1234 and 12345
Oct 29, 2007 | Motorola Mobility H700 Wireless Headset
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
