Honeywell cm97 digital thermostat number is display not showing fully
mastatech
  • 478 Answers
SOURCE: display is blank and furnace fan stays on
Remove wires at tstat Turn switch for furnace off than on.
touch the red wire to the white to simulate a call for heat.
Or Touhc red green and yellow to simulate a call for cool.
If that works get a new thermostat.
Posted on May 10, 2009
  • 334 Answers
SOURCE: Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Posted on Jun 11, 2009
  • 252 Answers
SOURCE: I have an old Honeywell thermostat (Chronotherm
you are not geting AC power from the furnace
Posted on Sep 27, 2009
  • 252 Answers
SOURCE: Thermostat not functioning correctly
-AC means there is no power coming from the furnace. not a tstat problem
Posted on Oct 04, 2009
billyvangogh
  • 108 Answers
SOURCE: How do I
There is a seam around the edge of the Thermostat , a small screwdriver or butter knife should do the trick , if not then its mounted to a plate on the wall that has 4 corners basically...Gently squeeze the bottom and pull the bottom out , they are pretty sturdy and you shouldn't have a problem,...the wall plate may flex a little while doing this
Posted on Oct 26, 2009
Display shows LLL
PDF]Chronotherm III 7 Day Programmable Thermostat - Honeywell
https://customer.honeywell.com/resources/techlit/.../69.../69-0352.pdf
O I" O 0. HEAT M10 COOL OF ow to operateyo. This Owner's Guide will show you how to get the most benefit from your new thermostat. Your new Honeywell ...
Sep 13, 2015 | Cars & Trucks
I just got a new Honeywell Utility Pro Thermostat. The digital temperature gauge seems very sensitive which results in the unit turning the furnace on and off for very short periods; much shorter than my...
Sounds like you also have a high efficiency furnace like mine.
Here is a procedure to slow down the number of cycles you are experiencing.
1. press System
2. press and hold buttons 3 and 5 on the bottom of the screen. (there should be 7 buttons displayed)
3. set code to 240
4. change setting to 3 for 3 cycles per hour. (your thermostat probably shows a higher number, probably 5? That is why your unit is cycling so often).
Jan 20, 2011 | Honeywell Electronic Programmable...
We have a Honeywell Digital thermosat. We just put brand new batteries in it and it is still showing lo battery.
on most of honeywell units if you pull the face of the thermostat off there is a reset button you can puch and reset try this.... if it does not have a reset remove the red power wire on the "r" terminal and if you have a wire hooked to the "c" terminal remove it at same time ///take batteries out prior to doing this and it will reset the program in thermostat... if the display comes back again with the lo battery the thermostat internally has a issue...good luck
Jan 09, 2011 | Honeywell Programmable Thermostat Heater
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
