Question about Ovens
Aeg oven competence rattling noise
Fan is not on It is on 180C Conventional setting but there is a rattling noise
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
  • 1462 Answers
SOURCE: clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Posted on Jul 14, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence oven fan not working
If fan has stopped altogether, then you definately need a new one, to be sure you need to disconnect and remove the fan and bench test it.
Hook up a 240v supply to the fan and see if it runs, if not then it is no good..
It does not matter which terminals you connect live and neutral too as it is common to both terminals. do not connect feed to earth by mistake.
Plz leave feedback.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
AEG Competence B3101-4m oven not working on fan setting. Fan operates but no heat. Also intermittent problem on full grill setting. Any ideas?
ISOLATE MAINS POWER BEFORE OPENING ANY PANEL
Several possibilites come to mind.
first Has this AEG two fans if yes , it has a top and back fan, the element on the back fan sounds like its either a bad connection or blown needs further investigation, the intermittent grill possibly a thermistat, of poor contact on a connection again. Rear and top panel access, you may have to remove the top fan.
Hope this has been helpful
John
May 31, 2011 | Electrolux Ovens
I have an AEG competence 5020 B fan oven (single) which has a very noisey fan, does this need a new motor and can I fix this myself?
ISOLATE THE MAINS POWER BEFORE OPENING THE REAR OF THE OVEN.
Remove the oven, open the back, remove the fan, and clean with WD40, afer the fan is dry, fit the fan back into the housing, replace back and put into cabinet, switch on low, if the fan makes a whirring noise, or unusual squeeking replace the fan, if however the fan sounds normal and good pressure when door is open, it should be okay. If you require a part go to whitegoods.co.uk
Hope this is helpful
johnf1
May 17, 2011 | Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
FAN COOKING MODE ON COMPETANCE B4101-4 NOT WORKING FAN WORKING BUT NO HEAT CONVENTIONAL MODE OK
If fan is working o/k, then you need to fit a new oven element.
Please rate my solution.
Thanks.
Sep 26, 2009 | AEG Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Ovens Logo
15 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
