Question about Technics SL-1200MK2 Turntable
Power failure my 1210 has a power fault. the pop up light has popped up and shorted out causing a total power failure. i have checked the fuses and the fuse in the plug but still no life. the power supply is working(humms) so i guess its a component on the board somewhere but i dont know where or what one. any help would be really helpfull as i cant mix on one deck! thanks in advance, darren
  • 1 more comment
  • darren
    darren Oct 01, 2007
    problem solved! it was transistor Q2 part number 2sd637.
  • darren
    darren Oct 28, 2007
    hi sneezing7
    i did a google search for a 1210 service manual, traced the circuit from the pop up light to the power supply input and did a simple voltage test on the way at each component.
    when i got to transistor Q2 the power went in to the collector but didnt come out of the emmiter.
    i did a continuity test across the collector and emitter and the turntable strobe lit up.
    i got a replacement transistor from the uk for £0.80.
    i hope this helps you out.
    darren
  • darren
    darren Nov 11, 2007
    hi again
    its likely your fault is inside the pop up light housing or a faulty bulb.
    if your not to bothered about the light just unplug it(as you look at the circuit board its the plug furthermost from you) or replace the bulb or buy a new housing complete with bulb from ebay for about £6.00.
    my fault came from over use i think,the wires just got worn out due to the pop up light coming up too far!
    i hope this helps.
    darren
Hi Darren,
Out of curiosity, how did you find out it was this part at fault?
My deck has just had the same thing happen to it :(. Unfortunately turntables are not popular in Cyprus, so it looks like I have to diy it.
Posted on Oct 28, 2007
  • sneezing7 Nov 11, 2007
    HI,
    Thanks for that. Ended up having the same problem!
    After replacing the 2 transistors, I still keep blowing them every time I turn on the pop up light. Obviously there is a short somewhere. Did this happen to you as well? Any hints where I can look for the short?
SOURCE:
My step son has a 96 S10 he replaced the pump a week ago, drove fine. after parking at the store it's popping fuses right and left? Anyhelp as always will be appreciated thanks Dave
Start looking for a short to ground. Check by noise (popping, sizzling), sight, (sparking) and feel-( a shorted wire may feel hot).
Check the engine compartment, especially around hot exhaust parts, under the car (see any loose wires?), and under the dash-listen and look.
You will need to identify the fuses, so as to know which circuit to check-or circuits if multiple fuses. Figure out what is common to all the blown fuses. Maybe the previous work of replacing the pump got some wires snagged or mashed and causing the shorts.
Jul 04, 2017 | Cars & Trucks
Replace fuse power cord board blown
hi, there seems to be dead short somewhere i'd unplug all the leads from the power board and plug one in at time, then power up the set to see which board is blowing the power supply hope it helps
regards
shaun
Feb 01, 2014 | Mitsubishi WD-65737 Home Theater
How to fix back lights that will nnot stay on
There is obviously a short to ground. The wire that supplies power to the lights is making contact with ground(gnd) causing the fuses to pop. Two ways to check. One is to physically trace the wire(s) to locate a broken or burnt wire. And the second way, though not recommended is to use a stronger fuse, turn lights on, and look for the smoke-where usually the short circuit is. Good luck.
Nov 12, 2013 | 1992 Chrysler New Yorker
RCA DVD Home Theater System popping noise now wont turn on
if no any power indicator the first place to be check is the power supply where in the fuse get blow. if the fuse blown with darkened color that was mean has shortened line, might the amplifier circuit get damaged that cause of popping before it totally down.check for bad amplifier ic and shorted diodes.
Jul 26, 2012 | RCA Rtd315w Dvd Home Theater System...
Had a radio installed it flicks or pops frm time to time but this maybe causing my fuse to pop and my car wont start. Had put a relay switch on about a month ago.helppp
Hi.
If there is popping sound and the fuse blows when the radio is flickering, then it is usually a short in the stereo wiring. The short results in excessive power draw and blows the main fuse. The radio must be removed to check the wiring behind. In some less common case the radio itself may be shorted inside becuse a defective PSU. If you have installed an amplifier check also that the problem is not the amplifier ordinary power draw, in that case the problem is fixed installing a capacitor in the amplifier power wiring.
Aug 06, 2011 | 1993 Acura Vigor
Television has no power. it made a pop and the screen went black resulting in no power to the television.
If there is no light on the front then the pop sound could well be a fuse blowing in the power supply. You could try removing the rear cover & check if any of the fuses have blown. If they have I would think the likely hood of it blowing again straight away is quite possible as usually the fuse will go due to a short circuited component on the PCB. If you have had any recent disruptions with your electric supply this can cause the fuse to pop & replacing it will solve the problem. If this is not the case then the best thing would be to contact your dealer to arrange a service repair.
Aug 18, 2009 | LG Televison & Video
Keep popping fuse on 1990 corsica...
You know whats connected to the fuse, now start systematically disconnect each component and each time you try the fuse same fault, reconnect, till you ge t to the component which you disconnect and do not blow the fuse, now you know it is in that component start tracing the wires/bulb connections. , have 10 spare fuses ready'
Aug 16, 2009 | 1990 Chevrolet Corsica
No power to washing machine
If this machine is totally dead and it tripped your home electrics - (which is probably a 30amp fuse) means that it is likely a serious fault in the machine. :-(
Washing machines take out ring main fuses if there are faults in the washers heater unit,motor or suppressor. Also water may have breached a seal somewhere and cause a short inside the electrical compartments. The flash you saw was probably some sensitive electronics and any smaller internal fuse popping. It is possible that simply replacing internal fuse will result in doing more damage once power is restored.
To fix a fusing washing machine you have to use a diagnostic electrical meter that puts high voltage across the appliance - Not something I can offer more info on. So whatever has happened (and in the interest of safety) you would probably want a qualified proffessional to take a look or as a last resort a hotpoint engineer!
Kind Regards
Feb 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Technics SL-1200MK2 Turntable Logo
193 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
