Question about Garden
Kill switch wiring - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Depends... most 4 strokes use a single wire from coil to ground kill system. I.E. wire goes to the kill switch ( key ) then over to ground ( safety switches come into play when dealing with riders, ztr's and big mowers. hand held equipment like weed eaters can either ground at the kill switch or go back to the block for grounding.
Posted on Oct 22, 2013
How to replace a kill switch on a husky 288 xp
There should be only 1 screw and one wire connecting the kill switch. The kill switch simply grounds out the ignition. So it is difficult to install improperly. The wire coming from the switch goes directly to the ignition module.
Jun 21, 2014 | Husqvarna 288 Kill Switch Wire Chainsaw...
How do you wire in a kill switch
just eliminate and cut off the wire to the existing kill switch the put any kill switch you want on it and take the main electrical lead to the ignition or what ever it is and put the new kill switch in the middle of the new kill switch you installed I did it before it always works just make sure to eliminate the old kill switch and its connections are no longer needed
Oct 30, 2012 | Coleman Electrical Supplies
No spark
Eigther the kill switch failed or ignition module. Disconnect wire to kill switch if you get spark then switch is bad. Still no spark with kill wire disconnected ignition module quit.
Sep 29, 2010 | Mtd Garden
I replaced ignition coil on a Tecumseh Toro 20018 mower. It would not start without disconnecting green "kill" wire. Now what do I need to do - replace the kill switch? Is the kill switch located on the...
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Aug 12, 2010 | Toro Garden
I have a1980 gs 850. i have no spark at the plugs. someone said i should start at the CDI box? How can you test this?
  • Start with new spark plugs. Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Check the fuses. How good is the battery? Is the handlebar kill switch on?
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing.
  • Then, If still no spark, get CDI system and coils checked at the dealers shop.
Aug 15, 2009 | Suzuki GS 400 E Motorcycles
Cant get my 50cc scooter to fire up-no spark. any
  • Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the side stand kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Is the handlebar kill switch on? Is it shorted out?
  • Check the fuses.
  • Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center or side casing.
  • If still no spark, get CDI system and coils checked at the dealers shop.
Aug 14, 2009 | 2005 Suzuki RM-Z 250
1983 yamaha xj 650 no spark already changed the cdi coil plugs wires and mag pick up what next?
  • Are you getting power to the coils?
  • Check the fuses. How good is the battery? Try a jump start from your car battery.
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center or side casing. If still no spark, get CDI system and coils checked at the dealers shop.
Aug 06, 2009 | 1983 Yamaha XJ 650
No spark
Start with a new spark plug. Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on?
Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing. If still no spark, get CDI system and coils checked at the dealers shop.
Jul 29, 2009 | 1995 Honda XR 250 R
No sparking on a 1979 YZ 125
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Also check the wiring harness for loose and/or dirty connections. Look for bad plastic connecton blocks and abraided wires.
Jul 26, 2009 | 2003 Yamaha YZ 125
Did I wire my Kill switch correctly on my '94 Yamaha YZ125?
if you were to wire it into the orange it will kill the motor.
do you get spark with kill switch on? if so definately wrong.
most kill switches go inline to the coil.
get some fresh fuel and try
Mar 19, 2009 | 2003 Yamaha YZ 125
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
