Question about Maytag Bravos MTW6600T Top Load Washer
My spin cycle isn't working ?? - Maytag Bravos MTW6600T Top Load Washer
  • 101 Answers
Lid switch not working, timer not working.
Posted on Dec 21, 2013
Washer spins but will not agitate
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Aug 14, 2012 | Frigidaire FEX831CS Top Load Stacked...
Will not spin
The final cycle of any washing machine, including Whirlpool units, is the spin cycle. During this cycle, water is sucked out of the load, preparing the clothes for the dryer. If your spin cycle isn't working properly, your clothes will be extremely wet, which increases the length of the drying process. Troubleshoot, and repair this problem yourself to save money
Jul 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Hi my washes agitators is working but it won't do anything else. It's not spinning or rinsing the clothes. the knob isn't moving from cycle to cycle. Even if I manually put it on spin cycle it...
Hello, Thank You for using FixYa. I will be helping you today.Check the lid switch. Since you didnt give a model number it makes it hard to figure out but sounds like the lid switch
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Roper Washing Machines
Spin cycle not working
When you say the spin cycle is not working do you mean that nothing works in the spin cycle. For example: Does the drum move or does it move and but the water isn't drained out?
Jun 19, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Maytag Bravos MTW6600T Top Load Washer Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
