Question about Sharpertek Ultrasonic Denture Cleaner CD-3900
Cleaning dentures - Sharpertek Ultrasonic Denture Cleaner CD-3900
Whiten dentures
You should be soaking them clean, at minimum, once or twice a week with an extra strength powdered cleaner. In between those days, use a regular tablet type cleaner each day. That will help to keep them clean, disinfected and as white as they were the day you got them. Don't expect to be able to make them whiter than the shade you had your dentist make them for you when you originally had them made. Unfortunately, you can only "whiten" your own teeth that you were born with, in that way.
Feb 26, 2015 | Dentures Health & Beauty
What is the cost of lower & upper dentures cost .
The cost of dentures depends on different dental professionals. The cost depends on the kind of dentures you want, as different kind of dentures has a different cost. Dentures are mostly made of metal, acrylic resin and porcelain. For more information, please click here - Learn more about CAD CAM technology with DT Technologies in Greater New...
Oct 01, 2014 | Health & Beauty
How do I remove my bottom dentures?
In order to remove your bottom dentures what you should do is to slowly pull on your denture while applying a rocking motion. Good luck!
Apr 29, 2013 | Health & Beauty
How do I clean my dentures properly?
Read this article for a great explanation on how to properly care and clean for your dentures:
http://www.mayoclinic.com/health/denture-care/AN02028
Can dentures break easily?
Hello;Yes Dentures can break very easy,be careful not to hold on one side while cleaning them.Lay them flat in the palm of your hand and brush gently then turn over and repeat step one.Also use A soft type Magic Eraser the type for kitchen and bathroom and make sure to clean them very well after with warm soapy water and rinse clean.You should soak them in A Denture cleaner over night so you don,t need to use so much pressure or just use the Magic eraser but be gentle.
Jan 15, 2013 | Health & Beauty
Cleaning stains inside corning perculator
Any easy way to remove those stains is to use denture-cleaning tablets. Fill/soak the piece of equipment in hot water and throw in a couple of denture cleaning tablets and leave overnight. Rinse out and wipe the next morning and it should be clean
Nov 23, 2009 | CorningWare Crock Pots & Slow Cookers
Sharpertek Ultrasonic Denture Cleaner CD-3900 Logo
80 people viewed this question
Top Sharpertek Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sharpertek Health and Beauty Expert? Answer questions, earn points and help others
