Www sanyoctv com
My manual says there is a PC (VGA) input for use as a PC monitor. Where is it? I have a DP42142
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Check for its connection details in the manual.
Posted on Oct 20, 2013
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
http://www.manualslib.com/manual/268264/Acer-S201hl.html#manual
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
Connect pc laptop
This TV has a PC interface VGA (HD-15) , so all you need is get a VGA to VGA cable to plug between the VGA output on the PC and TV.
On the PC select the display as external monitor.
On the TV pick the PC input as required input, not the TV tuner.
Here is the manual.
LCD TV 47HL167 Support Toshiba
Jan 05, 2014 | Toshiba REGZA 47HL167 TV
How to connect laptop to vga projector?
you need a cable. it may be the one that usually connects a computer to a monitor = depending what the input is on the projector but it sounds like an ordinary monitor cable as projector is VGA ( the other type has a digital input at one end ;but Im pretty sure thats not it.) If you have another computer set up just borrow the monitor cable and try it. There's already an input for one end in your laptop if its ok buy an extra cable
Mar 18, 2013 | Lenovo S405 14.0inch Laptop
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Compaq monitor wf1907 is saying dvi input/ no input signal. vga input/ no input signal. monitor says its goin to sleep
You should check the video cable and also try it with another PC since it is telling you that it is not sensing the video signals from your PC.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 25, 2011 | HP Compaq WF1907 Monitor
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
I can watch a movie from my computer to tv but the sound only came from the computer not on the tv
if you want the sound from tv, get an audio cable and put one end to computer where the speakers connected and the other to the audio input or aux in back of tv.
good luck hope it works, if so do rate the solution
Nov 28, 2010 | Vizio 42 in. LCD TV
I'm interested in connecting my dell latitude d610 to a tv
You will then need to select the PC input on the TV Now on the laptop you need to select the VGA output - have a look at the F keys across the top of the keyboard - should be one with a screen symbol - often F4 or F5 - but can be any of the keys Now using the FN key and the F key together will toggle the output for the following - but not necessarily in this order <laptop Screen only><Laptop Screen and VGA output><VGA output only>
the support site for that TV is here http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL40NX700&LOC=3
Online Manual http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL40NX700&LOC=3
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Dell Latitude D610 Notebook
How do you hook up tv to computer to play netflix off computer
Based on the model number, Zenith manual shows a VGA connector on the back. So if your video card has two connections then one can be sent to the TV and it becomes another monitor to your PC. Enabling the monitor is usually done through Display properties in your control panel. If you don't have a 2nd connection then connect the TV directly to your VGA output and let the TV be the primary monitor (select that input through your remote's source or input button) then boot the PC. You should see the PC video and boot process on screen. From there you can play Netflix or video games (Warcraft is awesome)
To get the manual for your model go to the link and fill out the requested info. You will need to dload a reader for the manual to show up.
http://www.zenithservice.com/index_b2c.jsp
Dec 05, 2009 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
