Question about Frigidaire Refrigerators
Ice keeps getting stuck in ice maker # fsc23r505b2
  • 998 Answers
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Posted on Oct 20, 2013
watugot
  • 290 Answers
SOURCE: Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Posted on Nov 18, 2007
  • 213 Answers
SOURCE: Ice sticking to ice maker
the water valve in the back where the water line conects is not letting the right amout of water pressure up to the ice maker. either valve is bad or if you have a filter it may need changing
Posted on Nov 20, 2007
Master_Tech
  • 770 Answers
SOURCE: Ice maker cycling but getting stuck
Either you have a bad heating element (soften the ice to eject) or a stripped gear in Ice Maker either way it will have to be replaced by the time you buy the parts and install them you can just replace the ice maker as a unit
Posted on May 10, 2008
rickzilla
  • 706 Answers
SOURCE: Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Posted on Aug 14, 2008
  • 9 Answers
SOURCE: Continental electric ice maker CE-IE65151. The
Look at the far ends of the shovel near the attachment hinges. There should be a little plastic tab near the pin on each end and on each hinge. They commonly break off. This is made by e_wave and their model is MCIM30TS. Order parts from Repair Clinic.com
Posted on Jul 21, 2009
Ice maker not working. Seems stuck. Freezer is cold. Ice maker does not move not water in try either.
After you have checked to see your water is turned on...
All the schematic diagrams I have looked at show a SEPARATE FUSE for the Ice Maker...
That is the cheapest and best trouble... and NOTHING will work without that fuse.
There is a separate water solenoid for the water... next cheapest issue (but you could eliminate that as a possibility simply by filling the ice tray manually)...
After that I would be ordering the Ice-Maker and keeping the old one for parts.
All the fill valve power and ice making SMARTS are inside the ICE-MAKER.
Good luck with that!
See below Ice Maker adj.
http://www.applianceaid.com/ice-fill-adjustment.html
Dec 04, 2015 | Refrigerators
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
Ice maker not making ice. ice in the tray, but will not dump the ice
Its the bar and gears that has frozen.
There is a stainless bar on the front of the ice maker. It move out and back to check for ice in the bucket. This bar is stuck and the ice maker thinks there is no need to harvest ice.
Try to move this bar and I bet it is stuck.
You can get a new Ice maker from Ebay and replace it yourself.
Jul 24, 2010 | LG LFX25960ST Stainless Steel French Door...
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Ice will no longer drop to ice tray
You havge a bad mold heater in the ice maker.
May 04, 2009 | Sub-Zero 642
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Nov 20, 2007 | Refrigerators
Refrigerators Logo
162 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
