Question about Kenmore Washing Machines
Kenmore 110-21102010 washer runs sometimes & sometimes wont spin even in spin only mode
My washing machine was acting up again and I suspected the switch behind the panel that controls the water level. It's a $100 fix to replace and I paid to have it fixed about two years ago. I came up with a work around by putting the washer on the 2nd rinse setting. Now it works perfectly. Cheaper than replacing the part but it's a shame that the manufacturers can't produce a better product.
Posted on Oct 20, 2013
5 Suggested Answers
  • 33 Answers
SOURCE: kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Posted on Dec 17, 2008
  • 686 Answers
SOURCE: Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Posted on Apr 17, 2009
landsend
  • 1066 Answers
SOURCE: maytag atlatis mav8551aww washer runs fine til spin mode then
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
Maytag317
  • 1136 Answers
SOURCE: I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Posted on Jun 27, 2009
I have a kenmore model 20422991 washing machine it wont agitate spin or drain but i can here the motor running
Thanks for choosing FixYa and welcome. Your drive motor controls the spinning, agitation, and draining. Even though it is running, the transmission may be bad. Replace the motor drive if this is the case.
Apr 02, 2011 | Kenmore 22422 Top Load Washer
Vic
Jun 27, 2009 | Washing Machines
Spins, drains, wont agitate
There could be a problem with the transmission/gearbox (but that would probably involve you hearing some load noise's). It could be that the timer just needs to be replaced,,, or its even possible that since taping the timer makes it work sometimes that there could be an electrical problem between the timer and the transmission/gearbox, liek maybe a rusted or lose wire.
Mar 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series washer
to answer your first problem,
if it wont stop filling, then the pressure switch is either defective,
or the hose that is attached to the drum to the pressure switch was either pulled out or had an opening either it breaks or it cracks.
that would not transfer the filling mode to agitate mode.
the second problem that it wont drain and spin now is another issue but might be resolve if you solve the first problem.
tnx 4 using fixya,
drcool
Aug 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore he2
the spin switch is broken. replace.
Dec 25, 2007 | Kenmore 43142 Front Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
190 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
