Question about Qca Spas Pool & Spa
Looking for a motor and wire for a Great Lakes Spa Forte 2004
5 Suggested Answers
  • 366 Answers
SOURCE: our great lakes spa digital display flashes
sound like you probably have a bad temperature sensor, or high limit sensor. "OH" usually means overheat and will shut the heater off. Have the sensors tested and go from there.
Posted on Nov 09, 2009
  • 8404 Answers
SOURCE: Great Lakes Spa pump. Any way to diagnose outside
If I understand your question, your spa pump will not spin up.
I believe your start capacitor has failed. Remove the back from the motor, you will see the black capacitor on the left hand side. There are several wires coming out of the capacitor. Somewhere on the body is a number. Get a preplacement from a FixYa.com advertiser, your community pool supply company or at www.repairclinic.com
Be careful as you service this electric storage device. Also, make sure you wire the new one exactly like the old one.
I believe this minor service operation will get your pump rolling again.
Thank you for posting at FixYa.com
Please vote
a
Posted on Nov 10, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: FL code on a Great lakes spa I have turned of
'Fl' means that there's insufficient flow of water through the heater, or non at all.
1) Check the water level - top up if low.
2) Ensure that all jets are open and flow water - if they don't you may have a pump issue.
3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
  • 111 Answers
SOURCE: Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Posted on Oct 30, 2012
I have a great Lakes Spas with two pumps. The first one works, but the second one will not come on. Could it be the switch or something else? Nothing happens when I hit the switch.
The pump might need to be serviced, look at the pump for water damage that's a sign it needs repair= bearing and a shaft seal can spark it back to life. and if you are handy you can check the power going to this motor.
Jay the pool pump repair guy longwood fl
Jun 30, 2017 | Great Lakes Spas Pool & Spa
My great lakes hot tub pump is on low speed and it will not shut off. I have it set to Ec mode.
One of two things either the thermostat is bad or the relay that controls the pump motor is stuck
May 27, 2016 | Pool & Spa
Need to print out control setting or hole manuel for 1996 great lake spa
Good Luck ; (
If you need control system operation assistance, find out the mfg'r and locate the proper numbers and search that way.
Spa manufacturer manuals are very difficult to get.
Nov 01, 2014 | Great Lakes Spas Spa Cover - GL-1SE
Our great lakes spa seems to circulate non stop
Could be a bad timer that will no longer rotate to the "off" dog.
Or a stuck relay in the closed position for the pump.
either replace the relay or the board if you don't have individual relays.
Naturally, check for proper operation of the relay 1st, before replacing arbitrarily. But you have a direction to go into now.
Sep 12, 2014 | Great Lakes Spas Pool & Spa
Great lakes spa model 733136
check with google they have answers for that and where to get parts
Jul 14, 2014 | Pool & Spa
F2 error code 2004
Balboa Direct has an excellent error code listing on their site.
Mar 29, 2014 | Pool & Spa
Great lakes hot tub
Normally f2 is not an error code.
It is informing you that you are in a "Filtration" mode. In this case Filter Mode #2
But, if we knew what make & model of the control system you have, will assist us better in helping you. Spa manufacturers normally do not use their own proprietary control systems. They will use a 3rd party vendors unit & install them on their spa.
FL code with Great Lakes spa ...Pumps won't run and tub is cold... light won't even come on.
FL code is because no flow from pumps check to see if recirculation pump fuse is ok
Aug 02, 2013 | Jandy Laars Lite2 Pool & Spa Heater -...
Please vote
a
Nov 10, 2009 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Pool & Spa Logo
37 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
