Question about Ruud Heating & Cooling
I have an e3eb020h furnace that, when I cut it on, the blower works fine, but I have a weird humming noise coming from the furnace unit. What could it be?
  • Robert George Jr.
    Robert George Jr. Oct 20, 2013
    Removed left side panel and the noise is coming from behind the right side panel where the circuit breakers are. Not getting any substantial heat output either.
  • 24 Answers
Humming could be a body panel or metal to metal point that came loose and just needs secured in the furnace or ductwork. could be an electrical issue that you may or may not be able to find with the doors off and trying to locate where the hum is coming from. it may go away when a panel is removed because it night be air sucking through a loose section of the door. the question is vague but I would press around while its running to see if it subsides. as always when its running with the panels off electric shock hazard and arc flash can occur causing bodily injury or death that's why they have the door switch which will cause the unit not to work with the door off. you can tape this switch to test the furnace but be very aware it is done on your own and I cant tell you it is ok to do this if you have no knowledge of electricity and its dangers. this is only for you to possibly find a hum and not press around on electrical components.
Posted on Oct 20, 2013
  • Robert George Jr.
    The noise is coming from behind the panel door on left side where circuit breakers are mounted. Fan is normal, but there is no substantial heat coming from vents when unit is running.
4 Suggested Answers
  • 124 Answers
SOURCE: Sears 92 gas furnace noise when not in air handling mode
a very subtle hum or buzz is normal and is the transformer that creates 24 volt control voltage continually. some are noisier than others . sometimes a tap or bending of the transformer will tweak the metal enough to make it quieter. they can also get loud if incoming voltage is not correct. incoming 120 volts on a furnace is not usually a problem but the transformers are usually wired to the available incoming 230 voltage or 208 voltage if it is a heat pump or electric heat. If it is powered by 230 or 208 volts as most heat pumps are ,then you need to verify which you have and connect the appropriate leads from the trans former to power . it tells you on the side of the transformer which to connect to 230 and which to connect to 208. tape or cap off any unused leads.since you have not mentioned any performance problems i assume the fan does come on when called for and that it is not the loud hum you hear. switching the fan switch at stat to on should bring the fan on right away. if it doesn't then you may hear a loud hum and then youll need to check the fan motor and capacitor. but it sounds like a noisey transformer from here.
Posted on Oct 28, 2008
kf4rwe
  • 25 Answers
SOURCE: Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Posted on Dec 03, 2008
co7196
  • 3433 Answers
SOURCE: AC unit turns on blower doesn't come on
The thermostat is the controller.
Posted on Jun 19, 2009
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
My heil n9mp2 isnt working just hums
is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
Jan 06, 2013 | Heating & Cooling
Hi i have an goodman capf036a2a furnace and when i cut on the heat the burner light but the blower motor doesnt turn its makes a humming noise and the code it reads is #33 roller blowout. do i need to...
Since the motor is humming we know it is recieving voltage, try spinning the blower wheel by hand and see if the motor starts up, if it does the capacitor needs to be replaced, if not the blower motor needs to be replaced.
Nov 28, 2012 | Heating & Cooling
Heat....Furnace will not start up worked fine last year it is getting power... I can hear I light hum in the furnace but it will not start it process
If its a high or mid efficiency furnace most of the time the sequence of operation goes as follows: tstat calls for heat (R&W at tstat ) ventor motor starts, pressure switch closes, spark or hsi lights pilot or main burners. main blower motor comes on. From your description of a humming noise it sounds like maybe the ventor motor is seized.
Oct 08, 2012 | Heating & Cooling
Hello i have Carrier Weathermaker 38tkb air conditioner unit. It's about 6 years old and when i got home today, the unit itself wasn't working. Although the blower fan in the furnace inside was blowing,...
The humming noise and dimming of the lights is an indication something in the outdoor unit is locked up or has failed.
Check the capacitor as it may have gone bad. If the capacitor is good, then you either have a failed motor, a failed compressor, or both.
Jul 07, 2010 | Heating & Cooling
My furnace just quit working yesterday. It worked fine till yesterday and now its not coming on. I can manually get the blower fan to come on by switching the thermostat from auto to run but there is no...
march 11 2010
Dear Ms.Mrs.
I would apply of your company? I'am a hardworking man, then i can handle any time of job?
Sincerely yours, Michael S. Anuada
Mar 11, 2010 | Coleman Heating & Cooling
Why two 24 Vac on aprilaire 700's control unit?
Okay, I looked up the installation manual online to see exactly what you are working with.
Yes the R anc C need to be hooked to the transformer supplied with the unit. The primary 120v side needs to be hooked into the power coming into the furnace. this can easily be done were the L and N get hooked into your furnace or circuit board on the furnace. This will provide the contiuous power to the unit. Preferably you will hook this after the door switch of the furnace so that you will kill the power toit if you take the blower door off.
The ODT terminals are for the outdoor sensor if you want to hook that up it will vary the humidiy in your home according to the outdoor temperature then.
Now the W/G and Cf terminals. If you have 24v coming from the HUM terminals of your furnace you DO NOT need a second transformer. You must check your furnace manual or check the voltage to them with the furnace blower energized. The HUM terminals will only have power to them when the blower should be running.
If the HUM terminals are 120v then you need to get another transformer and hook up the primary side to the HUM terminals so it is powered only when the the blower is running. Hook the secondary side to the W/G and Cf terminals.
So bottom line is that you need to figure out what voltage your furnace is giving to the HUM terminals and then go from there. Some times the EAC terminals or the ACC terminals will be 24v on the furnace board. Either of them could be used also, as they are only energized when the blower is running also.
Heatman101
Jan 25, 2010 | Aprilaire 700 Humidifier
Dec 03, 2008 | Intertherm Heating & Cooling
Goodman GMP075 Problem
check the mfds of the capacitor.if its ok you need a blower motor.
Aug 09, 2008 | Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
