Question about Refrigerators
I dont have a problem...just question. Can the very bottom (under door) be taken off th clean? And how does it come off?
  • 973 Answers
I assume its the kick panel you mention?? If so. most fridge panels are only clipped on. firmly grasp the panel and pull away from the fridge. Some are screwed in place. Have a CLOSE look for any screws etc before you go ripping the panel off.
Posted on Oct 20, 2013
Why did my ice maker in th efridge stop making ice what can ido
if its not feeding water too
remove the filter inside door bottom right , try water again.
Roll the fridge out look for the cutoff valve on the water supply an turn off water disconnect an drain or back flush or run some air or water in reverse , clean it out , test the water valve for water an expect some spraying of waters so unplug it all an git help.
Jan 05, 2015 | Refrigerators
My Neff S5443X1GB/07 dishwasher stops after approx 20 mins of washing, the water is nice and hot but it needs the door opening and closing several times to encourage it to progress a bit further of th
If your unit has a round dial timer (like many washer machines) the timer may be sticking. If it has an electronic timer then the door switch may be faulty. Don't run this unit unless someone is nearby, if the door switch shorts out, you may have a fire.
Jan 02, 2015 | Neff Dishwashers
Voice hearing totally disturbed while in call.
make sure that the earpiece is clean and is not filled with dirt . If so clean and try.tes with the headphone if clear then teh earpiece is faulty and needs to be changed.If not
next try to reset the phone with the battery taken out for sometime and the phone reset to default factory settings.
If both these dont work th software might need to be reinstalled..
Sep 30, 2010 | HTC Touch P3450 Smartphone
Dishwaher was inoperable for 2 weeks waitng for part, now theres a horrible smell like old water that perhapl leaked into the wall-the repair man did not take the whole unit out--i've put bleach,...
You should take out the filters in the base of the sump and clean them. also clean the sump. Then take off the door outer liner and clean along the bottom of the door seal. The bottom of the door seal is the worst place whaer a build up of greas forms. Once the lower door area is clean and the sump is clean get som descaler and run it through without dishes. You can buy dishwasher descaler or dishwasher cleaner from the supermarket. Keep the lower door seal clean regularly. dont put dishes i the machine with food on them. Dishwashers are not able to dispose of garbage, just grease from dishes. Good luckPS vinegar may help too.....
Aug 01, 2010 | Dishwashers
Over under Amana split door top frig
You may have an issue with a defrost component (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 14, 2010 | AEG S70408KG Bottom Freezer Refrigerator
Refridgerator is not gettting cold
there might be a leak in your condensor did you try cleaning your coils pull the grate off the bottom and clean coils ie vacuume or air compressors work the best blows everything off if that dont work try the reset button its in one of th corners on bottom turn with a screwdriver that might work
Dec 02, 2009 | Refrigerators
My fridge has decided that the light in the top portion is going to stay on all the time. It got so hot that the light cover melted. I've taken out the light bulbs and everything else works fine. The door...
heck you door alignment to be sure when the door closes it is hitting th lite switch and turning the lights off. sometimes it is necessary to put shims on the door hinges to raise the door to cause it to hit the switch properly.
Jul 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Jenn-Air Glass Door - How to Clean
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Aug 28, 2007 | Jenn-Air Jenn Air French Door Floating...
Black and white picture........
TAKEN FROM ANOTHER THREAD------
take the disk out. on the remote slide the bottom down. press and hold down the scan button 2 to 3 sces,then press right on the directional pad.your options is displayed on the machine
with disk i machine repeat above for brightness options
hope this is useful
bigdaveyl@hotmail.co.uk
Thank u big davey :P
Oct 01, 2006 | JVC TH-S3 System
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
