Question about Tablets & eReaders
Acer tablet a700 manual
After leaving my device on charge,I went to turn it on after leaving it charge up and could not do so.
    Master:
  • 193 Answers
SO sorry to hear this. I have seen to many tablets go BRICK after they are left to charge and then either they stay on the android boot/battery screen or they stick on the logo screen. There is a few things u can try to rescue you tablet.
First is this a acer tablet a700 or is it a acer iconia a 700?
I will assume its the tablet since if it was the iconia phone you would of been more upset for the 300 dollars plus. SO here we go and by no means can i tell u the exact reason these tablets fail or brick after charging.
This is a upper end tablet and not the cheap china clone. so hear is your first thing to try.
DO a hard reset with the keys first. WARNING reset can wipe out all ur data and set it back to factory if thats what u had it set to do. So if u have a sd micro card in its slot.. remove it and disconnect it from the computer dongle too. There are several diff options in recovery settings..back to factory or restore you settings from a backup file.. or wipe it and start all over.
so be aware that by doing a hard reset u can end up reinstalling everything u had on there.
Factory reset is first done with keys. HOLD THE POWER BUTTON AND THE SOUND UP but make sure you have the sleep / lock button right. at same time until it powers off..if not try power/sound up..this is the most common android tablet reset.
If this fails, then
The right side of the tablet is home to a microSD card slot (under a plastic flap) and a micro-HDMI port. The power/sleep/unlock key and 3.5mm headphone jack are located along the left edge, while a volume rocker and orientation lock switch are found on the top edge of the tablet, .
The micro-USB charging and syncing port, as well as a pair of speakers and a reset button, are located at the bottom of the A700
If u have made sure u have the sleep /lock switch in correct position. U have only one option left..the dreaded reset button. its on botton next to the usb sync charge port. Use a paper clip NO SHARP OR POINTS that break off.ie PENCIL lead .
DIsconnect from power and remove any micro/usb bridges..hold it in until it powers on and off..then cross your fingers and push the power button and wait.
If this fails to reset it back to factory and revive it. There are some software tools..SDK ANDROID isnt for the weak at heart though..lots of info and things that you will pull ur hair out trying.
If the reset above doesnt work..and u made sure its not in lock/sleep.. u are best off contacting the help line first and then last.
good luck my friend..
I will follow ur case..so post what happens and i will get it
Posted on Oct 20, 2013
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
My Visual Land Prestige Pro Android tablet will not charge
Visual Land Prestige Pro 7D Repair - iFixit
https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
iFixitVisual Land Prestige Pro 7D troubleshooting, repair, and service manuals. ... Tablet is fully charged but it won't stay on ... Why won't my device charge? ... The 7D runs on a newer Android 4.1 Jelly Bean, and has 1GB of RAM, compared to the ...
prestige 7 wont power on - Tabletroms.com
www.tabletroms.com > ... > Visual Land Tablets > Prestige 7
Sep 7, 2012 - 9 posts - ‎2 authors
I found this forum from searching about the prestige 7 and watching the videos ... It showed the charging animation for a few mins and then went off. ... I'd like to figure out what the problem is as I quite like the tablet and it was half .... prestige pro 7d won'tturn on. ,. visual land 8q has power but will not turn on. prestige 10D wont turn on after charging help!
Mar 23, 2014
Visual Land Prestige 10 charging issue
Jan 2, 2014
Ack... Help... Major Battery Issue!!!
Jan 24, 2013
Power Port Charging Issue
Jun 12, 2012
More results from www.tabletroms.com
Jan 07, 2016 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
I have a Icraig wireless touch screen tablet model number cmp773-GD , and it won't turn on or charge. Why?
If u just got it return it. your battery is died need new one.tip to make battery last longer. when u get a new battery by itself or it is part of something like a cell phone. do not charge most have half power right out of the box. use battery until it is 100% died.then charge it until full don't over charge. it is a trick to make your battery last long when it has a full charge. never leave battery charging overnight if done to much it makes the battery weak and wont hold charge for long. never leave charging cord plugged in when its not in use. when it is power from the socket is still flowing in the charger which is slowly frying it. that why most people go though up to 4 chargers for each device. i hope this helps have a sweet one!!
Aug 12, 2015 | Tablets & eReaders
Azpen A700 tablet. Why won't it charge or turn on?
If your Azpen A700 tablet won't charge or come on, you got no result trying to reset it, you've got only one option: take it back to the shop where you bought it and ask for authorized repair service, to diagnose cause of failure You even may have still option to warranty service.
Problem is that it's a low cost 35$ tablet so repair service might not be worth to pay, looks rather as a disposable device..
Aug 05, 2015 | Tablets & eReaders
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
My 7" sinotec 3g tablet screen just went white,then half white and black then black etc,whats happening?
Turn it off , wait some time tnen tor it on. If still there, leave it on till it discharges, charge it the turn it on again. If still so, take it for service on warranty
Nov 13, 2014 | Tablets & eReaders
Tablets & eReaders Logo
118 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
