Question about Microsoft Xbox 360 Console
The cd tray on my xbox 360 it off track, how do i fix it
    Problem Solver:
  • 5 Answers
Can you give any more details???
Posted on Oct 20, 2013
SOURCE: my xbox 360 doesn't play my games
Hey guys this is what I did. I took out the game so it doesn't scratch, turned off the Xbox 360. and then (I put my 360 horizontal [laying down]) I smacked the top of it a couple times. When I put the game back in it worked perfectly fine. I hope this works for you guys works :)
Posted on Mar 03, 2009
33mlake33
  • 142 Answers
Its definately an internal problem, just have the people at microsoft repair your console.
Posted on May 30, 2009
the lens of the disc drive needs a check up...
Posted on May 29, 2009
C-m0n3y
  • 34 Answers
SOURCE: the cd tray is off track
by buying a ps3
Posted on Feb 24, 2008
  • 46 Answers
SOURCE: xbox 360 black console tray won't open
does it try to open or is there no sound or movement at all?? my only solution would be to press eject and bash the side of the xbox to open the tray it works on mine!
Posted on Jun 17, 2009
Xbox 360 door tray off track and will not close
First, do not attempt to try to fix it right away. Unplug every cable and adapter, so you only have the xbox 360 console. Then, if a video game disc is still in there, take it out. Next, try to determine what your disc tray is stuck on, and try to remove it carefully. If these steps do not work, look at these articles. Manually eject your Xbox 360 console disc tray Xbox Disc Drive Solution.
Oct 11, 2014 | Microsoft Xbox 360 Console
Tip
Xbox 360 tray stuck closed
This is a common problem with many older units.
When you press eject the light flashes on the box
and the screen says" Open tray" bu nothing happens.
The cause is a weak eject motor , that is unable to
break the magnetic seal holding the cd rom against the
spindle .
If you press eject wait 1 second then smack the top
of the box HARD right over the cd rom drive your tray will
open .
The fix for this is to clean out the drive and re-lube all the
tracks and guides ,also gap the magnet in the upper hub
so it holds the cd with a little less force .That will enable
the motor to break the seal with out stallingout
Rob
on Dec 02, 2009 | Microsoft Xbox 360 Console
I put a game in my xbox 360 and when i close the tray it makes a weird noise like the cd is skipping or scratching then im at the home screen and it says "open tray" what is the problem and how do i fix it
do you stand your xbox up? maybe for some reason the cd isn't sitting in the tray. if you have it vertical try laying it down and see if that still happens. hope i helped
Mar 03, 2010 | Microsoft Xbox 360 Console
My xbox 360 disc tray wont open how do i fix that problem
Slap the top of the the box as you press eject. that will get it open.
then wipe a little rubbing alcohol on the black belt
just under the tray . And a little petroleum jell in the
tracks under the tray . Then open and close the tray to
work it in.
Rob
Sep 19, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
check if you CD is break in the center. If it break, go in a EBGAME and told them your problem.
May 30, 2009 | Microsoft Xbox 360 Console
CD tray
If you want a try fast get one off ebay. You just need to know the model of your dvd drive. Who serviced it and left out the tray???
Mar 22, 2009 | Microsoft Xbox 360 Console
Door does not stay closed
The number one quick fix for the DVD drive is to re-align the tray. This is common with CD players, CD changers as well. Many times just from normal use a gear will skip or something will jump track, unless all the pieces are in the right place at the time it powers up it will not work. So by removing the tray, aligning the internal parts to their starting position and re-inserting the tray you can often bring a drive back from the dead
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 06, 2008 | Microsoft Xbox 360 Console
Xbox 360
Your tray needs new alignment. Try opening up the CD Drive and disassemble it up to the tray. Take the tray out and re-align it. Try looking for tutorials on how to fix the DVD drives. I can't really explain that well about how to re-align the tray of the CD Drive.
Dec 21, 2007 | Microsoft Xbox 360 Console
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Microsoft Xbox 360 Console Logo
122 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
