Question about Kitchen Ranges
Frigidaire stove Stove top heat controller not working,it goes on full even when you put it to minimum heat.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Replace the burner control switch...the button you use to set the temperature of the switches.
Posted on Oct 20, 2013
4 Suggested Answers
SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Posted on Jan 02, 2009
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
Posted on Oct 21, 2010
I have a Frigidaire ES 100/105 electric stove that is about 1 year old and has just stopped doing anything - no lights, no heat in stove or on stove top. nothing. I have power to the outlet so it is
Hey friend, I appreciate your post! It sounds like a possible issue within your control panel or a faulty wiring harness. I would recommend seeking assistance from a professional for further proper diagnosis and repair to avoid any unnecessary part purchases. If you need any additional assistance please feel free to reconnect. -Matt
Oct 10, 2014 | Frigidaire Kitchen Ranges
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Stove Top won't heat
clock works because its only 110 volts.all else is 220.as a repair man the firstplace i would check is the cord.[power off]why there first the installers dont know how important it is for those cord screws to be very tight.consequintly the leave them looseish,and thats where they burn.if thats ok.make sure you have 220 there at the cord.God bless you,tom
Jan 02, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Stove won't heat
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
