Question about Dacor Kitchen Ranges
Dacor ERD48 Range. The circuit board went dead. No lights at all. Time flashed a short while (as if there was a power outage) then nothing. I assume I need the board repaired or replaced. How do I remove the board?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
There are screws somewhere around the board housing. First check below the control panel just above the door. There might also be one screw on the ends of the control panel. Usually you do not have to remove the knobs to do this.
When you get to the board just behind the panel, it might be held down further be clips at the edges.
Posted on Oct 20, 2013
Testimonial: "No screws around the board housing. The only screws I see are those that hold the stove top to the unit in the very front of the burners. Do I have to remove the stove top and burners?"
SOURCE: All lights on the touch panel are flashing and a continous beeping sound
bosch 700 series range. So far unplugging the range and waiting several minutes to plug back in reset everything like rebooting a computer.
Posted on Apr 30, 2008
dovaleh
SOURCE: Dacor Oven Death
hi,
i think first you should call dacor, 4 months is marginal - they should cover it
but if all else fail you can try this link ti diagnostics manual:
http://dacorservice.com/PartsCatalog/docs/ProductModels/437/Diagnostic_Manual.pdf
and this link to dismanling instructions:
http://dacorservice.com/PartsCatalog/docs/Ranges/Service%20Manuals/ERD30s06_sm.pdf
good luck
dov
Posted on Jan 10, 2009
SOURCE: oven does not work
Its 220 volts and ge only turns of one leg of the 220 vols so you always have a hot side NEVER work on any thing thats still pluged in.
You could have killed yourself if you touched graond while you pushe the hot conecter on to the burner. Try reseting your house bracker If that don't work Look a the relays and wiring in the stove.
Posted on Jul 08, 2009
SOURCE: Dacor oven light bulb
Yeah, it's a rip-off isn't it? Been there. :-( Find the bulb part number or electrical values and search eBay. I think this is what you're looking for:
G4 halogen 12v 10w, dacor part 86364.
A search right now shows multiple vendors offering 10-piece packs for $7.00 including shipping. I'm about to order a set myself.
Posted on Nov 24, 2009
No power at all after an power outage
Before you investigate the TV and its power supply, have you confirmed that the outlet is still delivering the voltage? Sorry if I ask but you said you turned everything back on after the power failure and I didn't know if you meant equipment in the house or all circuit breakers in the house.
Dec 31, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Where is the model # on an older 48" range w/ 2 ovens?
Epicure ERD48 quite likely is your model number and unit information is usually located on a sticker on the back panel of any unit
May 19, 2012 | Dacor Epicure ERD48 Dual Fuel (Electric...
Hi - the Dacor ERD 48 oven doesnt heat to the set temperature - usuakky 25 - 50 degrees below the set temperature. Any idea how to correct this?
Read the troubleshooting tips on the below link as it might be helpful in solving the problem;
http://www.partselect.com/range-stove-oven+Element-Heat-Incorrect+repair.htm
I hope the above helps. If it doesn't, please let me know so that I may direct you further.
Good luck.
Jan 04, 2011 | Dacor Epicure ERD48 Dual Fuel (Electric...
How do I convert a dacor epicure range ERD48 from liquid propane to natural gas
Just change the orifices. Also adjust the pressure control regulator by reversing the built in plastic spacer, the regulator supplied is a dual fuel type. Any work should only be carried out by a person who is qualified to do so for safety reasons. Dacor are very unhelpful when I posed the same question directly to one of their technical advisors. The poor level of this persons 'technical' knowledge both surprised and concerned me.
Jan 22, 2010 | Dacor Epicure ERD48 Dual Fuel (Electric...
Electric range heard a loud bang then it went dead
I WOULD DISCONECT THE POWER AND REMOVE THE BACK PANNELS AND LOOK FOR A SHORTED WIRE OR A BURN MARK ON THE BOARD. ALSO CHECK WHERE THE CORD ATACHES TO THE STOVE. GOOD LUCK!
ERIC
Jan 17, 2010 | Kitchen Ranges
Dacor smooth cooktop lock light flashing... nothing works!
Hold the lock button down for 5 seconds to see if it will unlock
Jan 20, 2009 | Kenmore 78823 Gas Kitchen Range
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Jan 27, 2008 | Televison & Video
Dacor error messge
The Door lock safety circuit on power relay board sensed. Check your power relay board and door lock circuit. F9 indicates the problem is with the lock circuit. Shut the power off and see what happens if nothing then do the checks. You can have a problem with the latch assm. the lock switches the relay or even the ERC (electronic range control).
Dec 20, 2007 | Dacor Preference RSD30 Gas Kitchen Range
How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
Kitchen Ranges Logo
139 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
