Question about Emerson LC391EM3 39 in. LCD HDTV
Zoomed in - Emerson LC391EM3 39 in. LCD HDTV
How do I enable samsung tl105's digital zoom?
From the manual:
Optical zoom TELE : Push the Zoom W/T lever to the right to
enlarge the subject.
Digital zoom TELE : Push the Zoom W/T lever to the right again
in optical 4x zoom mode to enable digital
zoom (software tele). Release the Zoom
W/T lever to stop digital zoom (tele). When
the 5X digital zoom reaches its maximum
magnifi cation, it will not enlarge the image
further, even if you push the Zoom W/T
lever.
Jul 18, 2010 | Samsung TL 105 Digital Camera
Zoom function
Yes. This camera has 3x optical zoom and 4x digital zoom. However digital zoom cannot be used in 2880 x 2160 size. Optical zoom: It is approximately 5.6 - 16.8 mm. (equivalent to 38 - 108 mm on 35mm film camera) Digital zoom: It extends to 4x from telephoto end (108mm) of optical zoom.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
Super Zoom
In addition to the optical zoom, this camera is equipped with a super zoom and digital zoom for taking telephoto and wide-angle shots. The super zoom and digital zoom cannot be used at the same time. Super zoom is used to extend the optical zoom up to 14× magnification. However, the resolution is automatically fixed at 1600 ×1200. Digital Zoom is used to extend the maximum optical zoom to approximately 40x. However, pictures taken with the digital zoom may appear grainy. Camera shake is likely to occur at these higher magnifications, please see “camera shake” question for further details on this.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Super Zoom
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Telephoto zoom
The D-565 camera has a 4x digital zoom, in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Telephoto images
The D-630 has a 3x optical zoom and a 4x seamless digital zoom. In order to use the digital zoom, press the OK/MENU button on the back of the camera. Press the right arrow key to access the Mode Menu. The first setting under the CAMERA tab is DIGITAL ZOOM. Press the right arrow key to highlight this setting and then press again to select ON. Press the OK/MENU button to set the DIGITAL ZOOM to remain ON. When you press the zoom button with the T on it, a zoom indicator will display on the right side of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. When the zoom indicator is in the red zone, you are using the digital portion of the zoom. images taken in the digital zoom will appear “noisy” or “grainy” which is normal when using the DIGITAL ZOOM.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Telephoto images
The D-595 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Telephoto zoom
The D-575 Zoom has a 3x digital zoom and a 3.3x digital zoom, which gives you a total zoom of 10x. Use the shooting mode menu to activate the digital zoom feature. The D-575 camera has a 3.3 digital zoom, which gives you a total of 10x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Telephoto images
The D-545 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Options for more telephoto zoom
The D-535 Zoom camera has a 4x digital zoom in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Emerson LC391EM3 39 in. LCD HDTV Logo
14 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
