Question about Epson P50 Inkjet Printer
My epson stylus p50 doesn't respond,it require service for ink pads,what can i do?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
If its in warranty call to customer care or check the manual
Posted on Oct 20, 2013
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
ChobPT
  • 220 Answers
SOURCE: Epson Stylus Photo R300 has error
You actually need to change the ink absorber.
Heres a video on how its done on the R800.
Please refer to your manual for proper localization of the ink absorber.
Doing this will get you to move on
Posted on Jun 20, 2009
SOURCE: service required for EPSON STYLUS R230
service required
Posted on Jul 28, 2009
SERVICE REQUIRED
This is where the printer may have filled the purge ink pad with ink.
When you clean the print heads it pours out loads of ink onto an absorbent pad. This gets full after a while and needs changing. If you can locate it and remove the wadding and replace it with other cotton based wadding you should be good to go.
Mar 11, 2015 | Epson P50 Inkjet Printer
Epson P50 does not respond. Blinking lights and stuck cartridges.
This is a standard "Service required" issue where the waste pads (or nappies) in the printer are considered full by the printer and it wants them changing.
An Epson service centre can replace the pads and reset the waste counter for a considerable amount of money although most it seems either tell you it's dead and recommend you buy a new one, or they reset the counter, ignore the pads and leave you to flood your printer.
The more cost effective option is to locate one of a number of reset utilities such as the AdjProg utility for the T50 (it's compatible with the P50) and an external waste ink kit (like the Printer Potty).
The latter is easy enough to fit on a P50 thanks to the access hatch located in the rear left quadrant of the printer.
More information and instructions are available here:
http://www.wasteink.co.uk/waste-ink-mods/epson-r285-mod/
Jun 29, 2012 | Epson P50 Inkjet Printer
Epson stylus TX121 printer's ink pads are at the end of their service life
My printer name
Epson tx121
it's show "The printer's ink pads are nearing the end of their service life. Please contact Epson support".
May 14, 2012 | Epson Stylus TX120 Inkjet Multifunction...
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
Message "Service required. Parts inside your
You'll probably find that that the print head is worn out (according to Epson) and it needs to be replaced. It's cheaper to buy a new printer.
Mar 13, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
Dirty Waste Ink Pads (Epson Stylus R285)
Remove to top cover and replace the ink pad with a new one. You can get these pads from a place called pudsey computers www.pudseycomputers.co.uk
Nov 17, 2009 | Epson Office Equipment & Supplies
Stylus Photo 1400 Ink Pad Replacement
Hi, if you change wast ink pads it will cost too much.
The best way to resolve this matter is Do it by your self.
You can purcahse wast ink bottle from us then use EPSON reset software to reset wastink pads.
After this done your printer will back to normal.
If you require more information related this issue you can email us free of charge
service@rextras.com
Kind Regards
May 15, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
We r have epson c45 stylus printer.after initialise red and green LED's blinging
The Waste Ink Pads are deemed to be saturated and should be replaced. You can overcome this problem temporarily bu using the SSC utility - download from
and reset the Protection Counter. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual.
Jan 09, 2009 | Epson Stylus C46 InkJet Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson P50 Inkjet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
