Question about Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK
Need a video how to program my keyless entry deadbolt lock
  • 5,102 Answers
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Posted on Oct 20, 2013
Where do i find the english instructions for installing Garrison keyless entry deadbolt lock? 046-2667-4. Got only french in box
Is this model sold in the USA or Canada? If not then you may have a problem getting the booklet in English. You could post the instructions and then use google to translate them.
Aug 12, 2016 | Deadbolt Locks & Locksmithing
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
You can shake front door when locked and the door is loose not tight
It sounds like the distance between the lock in the door and the strike plate in the door frame is barely enough to meet securely. Review the lock installation sheet because it MAY be possible to adjust the "backset" for your lock. You did not mention your brand of lock. For example,
Review Steps 1 & 2 of instructions for the Powerbolt:
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Or watch this excellent installation video for the Schlage BE365, at about1:58 minutes into the video you will see how to adjust the backset:
Go to
http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspx#2
Then click on "Installing your BE365 Keypad Deadbolt" video.
Many brands of lock have a similar backset adjustment, and you may have your set too short.
If yours is all ready set for the 2 3/4" backset, then you need some carpenter skills to close up the door gap.
Sep 28, 2012 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
How do I program in another 4 digit code for entry?
I'm providing a link to the video which explains the programming process:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Apr 21, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
How to reprogram code for keyless entry
A set of my keys and remote were stolen and
I need to disconnect my keyless entry but I don't know where it is located
Oct 02, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK Logo
737 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Mark Wolfe
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
