Comfortmaker I need to replace my Confortmaker Condensing Unit Model CAC448GKAS and cant find the tons?
  • 24 Answers
Need more info on condenser itself the model number not coming up but the nomenclature u gave looks to be a 4 ton unit. why I say that is the 48 normally represents the btu's 12000 btu per ton. so 48 represents 48000 btu 4 ton. now this depends on your house 400 square feet per ton is a rule of thumb without doing a proper house inspection. how many windows type of windows all kind of stuff. so 4 ton is roughly good for a 1600 square foot house depending on all kinds of variables. if I can get a full model even if it shows ----00-- something like that I can give you a for sure answer. u may even get an r-22 unit which u can buy only as a dry unit companys still make them but can no longer ship them with r-22 in the they come charged with nitrogen which will save you a few grand on install because you don't have to change the indoor coil to a proper sized 410 a coil or the lineset. be aware of contractors who tell u to keep the indoor coil they will add a expansion valve and flush the lines with r-11 or rx-11 flush u wont get the efficiency or 100 percent working condition of a mix mash system.
Posted on Oct 20, 2013
farfield
  • 462 Answers
SOURCE: Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to rep
A new unit will be 13+ seer unless you can find someone that has replaced a compressor or has one left over from pre 2006 stock. Our wise Government with all its resources decided that we aren't smart enough to turn off the lights to save energy, so they chose to end the med and low price lines. And the same bunch of smart ones decided that now R22 because of its chlorien content being bad for the air (5% of what R12 was) so we have R410A and others that no one knows how much cancer or daMAGE THEY WILL DO OVER TIME. So now if you replace your AC unit out side with a new one be sure its compatable with the refrigerant inside and beware soem manufacturers wont stand up to full warranty if you dont buy an indoor coil and rerplace it too.
We get what we deserve in Washington DC and if our guy didnt support this stuf too many other folks guys did. We just dont talk about it enough. AND WE SHOULD. But then again you like me are probably RITCH. So we have to give up our wealth to the government so they can redistribute it and buy more votes. And we can stay working too much to talk about it.
Just burns my back side like a 4 foot flame.
Read tween the politics and you'll get my recomendation.
Buy your self a compressor and get someone qualified to install it or see if the old goodman one will interchange easily.
Posted on May 12, 2009
james3751
  • 614 Answers
SOURCE: Can Air Handler !1/2 ton run with 2 ton
Its done all the time. It is sometimes better to do this because you run a colder coil and rmoves more humidity. The newer unit have variable speed fan and run slower to do the same thing. Remember the lower the humidity the higher you can raise your tsta. Example In arizona at 95 degrees you dont feel the heat as much because of the lower humidity. Its ok to do so. You get more btus out of your unit that way. Rus. I have dozens of units with air handlers 1/2 ton smaller...
Posted on Jul 18, 2009
  • 10 Answers
SOURCE: what type of freeon gas does it take
There should be a nomenclature tag on the exterior of the unit by where the electrical enters the unit. It states the refrigerant type .
Posted on Nov 08, 2009
  • 1150 Answers
SOURCE: how do i tell what ton my ac condensing unit is by
get me the model number and I'll tell ya.
Posted on Feb 03, 2010
  • 23 Answers
SOURCE: I have a 3 ton split system using a Rudd 3 ton
Both the other solutions are NOT proper Advice, i'm not saying this a put down, but if you want it to be right both of those answers are wrong
The truth is if you replace the condenser weather its a heat pump or strait cool, you need to match the equipment inside, ALWAYS use matched equipment otherwise your setting yourself up for failure. I've seen a ton of mechanics in my industry really mess people up by mis matching, Also you can install or service anything with refrigerant in it with out an EPA license. Trust me do it right, cause I hate having to tell people after its to late. Another thing these two are not telling you is that you need to match the metering device to the outdoor unit in order for it to work properly as well, and by the FLUSHING is risky on a coil, ok with line sets but risky with a coil.
Posted on Oct 01, 2010
I have comfortmaker cooling and heating system. Model fby036cb1.and serial L952594814. I just want to know how many tons in this unit? Thank you.
Based on your model number, looks to me like its a 3 ton (036).
ie. 024 is a 2 ton. 036 is a 3 ton. 048 is a 4 ton. Etc etc
May 06, 2015 | Heating & Cooling
Need Minimum Circuit Ampacity and the Maximum Fuse Breaker for the Condenser - Thak you
Serial numbers don't tell much.
Model. numbers describe the unit best an 18 in the model is for 1 1/2 ton,24=2 ton, 30 =21/2 ton 36=3ton etc
May 02, 2015 | Heating & Cooling
I have a Carrier Weathermaker model #38tdb060300 A/C system. How many tons is that? It is 11 yrs old, capacitor exploded and compressor is blown. Needing to replace.
Looks like a 5 ton unit. However, you might be better off finding a R-22 condensing unit to replace the entire outside unit. Reason being, if you just replace the compressor, you get a one year warranty. If you replace the whole outside unit, you get a 5 year warranty. You can replace the outside unit with any manufacturer, as long as it is the same tonnage and type (heat pump/air conditioner/single stage/ 2 stage ...).
Oct 13, 2014 | Heating & Cooling
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
What is the ton of my comfortmaker ac unit model ac030gb
Hello, this is a 2.5 ton air conditioner. There are 12,000 btu' s per ton
Jun 07, 2012 | Heating & Cooling
Hi I purchase a 3 ton -3 phase condensing unit. Dayton model 1nxd4 for a friend house,after the instalation was finish the unit will not turn on. after installing the unit i found out that the unit was...
Three Phrase is usually only avail at a commercial
business
You would need a complete additional service to the house just for the AC
They would have to install a new transformer on the pole
I would suggest replacing the motor if that is the only issue,
to single phase 240 volt
May 23, 2011 | Heating & Cooling
What size BTU unit is my Crarrier model 38ck036330 condensing coil ?
The model you gave is for a 3 ton or 36000 BTU unit...that is what the 36 stands for in the model number...
heatman101
Aug 24, 2010 | Carrier Heating & Cooling
How many tons is the condensing unit serial # 10AJB36A01
3 tons. 12,000 btu per ton divide 36 into 12 = 3 tons
May 19, 2010 | Heating & Cooling
Can't identify ton rating of condenser unit
the model number tells me it's a 4 ton. the 048 is what it gives it away. 1 ton is 12,000 btu's . 4 ton is equal to 48,000 btu's
May 23, 2009 | Heating & Cooling
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
