Math Division 1600/24 how is the answer 66.6=67
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
1600 divided by 24 is 66 2/3 or in decimal, 66.6666 with the 6s repeating forever. Rounded to the nearest whole number it's 67 since it's closer to 67 than to 66.
Posted on Oct 20, 2013
How to do Order Of Operations and algebraic expressions with division and multiplication and subtraction and addition for 6th grade ONLY
here you go.
Grade 6 Math Circles Algebra Order of Operations (BEDMAS) - CEMC
www.cemc.uwaterloo.ca/events/mathcircles/2013-14/Fall/Junior6_Oct8.pdfGrade 6 Math Circles ... Suppose you are asked to evaluate an expression that looks something like this ... When an expression contains many operations, we must be careful of what order we do ... sion and multiplication, and finally addition and subtraction. ... According to BEDMAS, division is a higher priority than addition. How to do Order Of Operations and algebraic expressions with division and...
Apr 24, 2017 | Office Equipment & Supplies
Need help with math And division. And place value
Hi Tanrika...what is your math question?
Regards,
Dennis
Oct 10, 2014 | Office Equipment & Supplies
I have a math problem
The answer is 90. You must perform the operation in the following order: Multiplication and division first, then, addition and substraction as required.
Nov 13, 2013 | Learning Resources Positive & negative...
Why cant anyone tell me how to do fractions on my calculator i dont have the / button
Yes, you do have the division key. It is the division key. However, if you want the fraction to remain a fraction, enter the numerator, press the division key, type in the denominator then Press [MATH] [1:>Frac] then press ENTER. The fraction that will be displayed will be the reduced form.
Sep 19, 2011 | Texas Instruments TI-82 Calculator
How do I enter a fraction on my TI-84 Caclulator and get a fraction as an answer? If I hit (Math) then (1:Frac) and put in a fraction and hit enter it tells me error. What am I doing wrong???
To Enter a basic fraction just enter the first number, then a division sign, then the second number. So two thirds would look like "2/3" (Without quotes). For more complicated fractions you may need to put parentheses for the left and/or right of the division sign like in the fraction (5+2^4)/(2-8). To get the calculator to show it as a fraction you would enter the fraction, then press (Math) then (1:Frac). So the input on your screen should look something like this "2/3>>Frac" (Without Quotes, and >> being a filled triangle pointing at the word Frac). From your post it sounds like you were putting the fraction last when it should have gone first.
Jan 28, 2011 | Texas Instruments TI-83 Plus Calculator
How do a take a division problem and square root it on a TI-84 Plus Silver Edition for example 87.34/5 then square root the answer. I can do the math, but how do I take the dvision answer and square...
Two ways:
2ND [square-root] ( 8 7 . 3 4 / 5 ) ENTER
8 7 . 3 4 / 5 ENTER then 2ND [square-root] 2ND ANS ENTER
The first sequence takes the square root of 87.34/5, the second sequence calculates 87.34/5 then takes the square root of the result.
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
How do you enter a fraction
A fraction is just a division of two integers. Enter numerator, then press the division key and then the denominator.
If you press ENTER at this time your fraction will be calculated and displayed as a decimal number.
To keep it in fraction form you must press [MATH][1:>Frac]. The result will be a fraction but reduced to its simplest terms (an irreducible fraction).
27 [/] 48 [MATH][1:>Frac][ENTER] gives 9/16
Aug 17, 2010 | Texas Instruments TI-83 Plus Calculator
How do i do fractions with this calculator? there are so many keys i dont know what to push.
The primary key to enter something that resembles a fraction is the division key, the one above the multiplication key.
However, any division you enter yields a decimal number, unless the result is an integer.
To keep the result of a division as a (reduced) fraction use the [|=>Frac] or [ToFrac] command. It is accessible by the following key sequence
[MATH][1:ToFrac].
Insert it after the fraction, before pressing the [ENTER] key to get the result.
By pressing [MATH][2:ToDec] you convert a fraction in to a decimal number.
Apr 10, 2010 | Texas Instruments TI-83 Plus Calculator
Simple addition
First you're going to want to navigate to the Home icon that is on the main screen by using the arrow keys, then once you press enter you will arrive at a different screen and you will be able to enter numbers and symbols at that screen. once you press the appropriate keys for your math problem you will then want to check over that problem and once it is what you want you will then want to press the enter key. The answer should come up. If you do a division problem though, it will just give you a fraction, to get a decimal answer you will then want to press the green diamond key and then the enter key in one extra keystroke to get your final useful answer.
Sep 08, 2008 | Texas Instruments TI-89 Calculator
How to do fractions.
A fraction is just division of the numerator by the denominator.  So all you have to do is enter the division symbol in place of the fraction bar.  If you are trying to enter a mixed fraction: for example 3 3/5 enter: (3+3/5) were the / is the division button or your calculator.
Sep 03, 2008 | Texas Instruments TI-83 Plus Calculator
k24674
jasbo
jasbo
