Question about Sega Mega-CD Console
Cant get power on sega cd 2. hooked up with genesis 1 console. both ac adapters work and genesis works fine. don't see any fuse inside sega cd
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
The fuses are solid state fuses, one is a small white top surface fuse on the bottom of the board the other is a green "resistor" looking fuse. both are marked with Fxxx ( the x's are numbers) check them with a meter for continuity so you dont change a good one.
Posted on Sep 04, 2015
  • 20 Answers
SOURCE: no picture for Genesis - RF or console?
The problem is most likely not the console. The first thing you should try is cleaning the contacts on your games. Most of the games have tamper proof fasteners so unless you have the right tools you won't be able to open them. You can take a q-tip with a little alcohol (damp not wet) and clean both sides of the circuit board on the cartridge until the q-tip comes out clean. Let it dry before sticking it into the console. If you do this to a couple of games with no luck try taking an emery board (for fingernails) and gently inserting it into the connector in the console a few times all along the length of it. Make sure to only push it straight in and pull it straight out. If you try pushing it side to side while it is in there you could damage the connector.
Posted on Dec 08, 2007
  • 53 Answers
SOURCE: Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Posted on Jul 11, 2008
jyackle5
  • 8197 Answers
SOURCE: I need hook-up instructions for my 16 Bit Sega Genesis system con
Go to this link.
http://imageevent.com/gamescans/gamemagazines/segagenesismanual
Good Luck
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: Power, But No Picture!
Try moving the a/v or rf cable in the back of the genesis
Posted on Jun 13, 2009
DarkWolfBomb
  • 80 Answers
SOURCE: how do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
Posted on Jul 18, 2009
Sega genesis wont start up
I had had a problem with my old Sega Genesis console the red light would not turn on even though I had turned the power on after a few se the voltage regulator got very hot really fast you could have a similar issue like I had for this if it is stone cold then it is dead. Try another ac adapter too see if it works if it does work then the ac adapter was bad. If there is no power light being on and it gets really hot really fast then it could be the capacitors that are causing it not to work or the voltage regulator is not working right. So you could buy a new one then.
Dec 23, 2013 | Sega Genesis Console
My sega genisis isn't working on my LCD screen
2q== they have videos on Youtube on how to hook Sega genesis version 1 2 and 3 consoles on up to a flat screen tv or any of the newer TV's. I just use a CRT style TV they are much easier to hook up old consoles too. Just buy a CRT tv type then.
Sep 28, 2013 | Sega Genesis 2 Console
My sega genesis won't work - it was working fine
You screwed it up by plugging it into the 64. It is too old to handle that kind of stuff. I reccomend going and getting youself a Xbox 360 slim. They are much more efficient.
Oct 29, 2012 | Video Game Consoles & Games
Sega Genesis Model 2 won't turn on
Well it sounds like that you have a bad ac adapter then so buy a new ac adapter the console is fine so just a new adapter that's all.
Apr 28, 2012 | Sega Genesis Console
The audio on my sega genises 2 doesn't work, and it's not the cable because ive tried different ones, is there any way i can fix it?
Well it might be an internal issue with the console like the parts inside of the console that
allows there to be sound and controlls the sound might be broken or you could buy a new ac adapter to see if it makes a difference.
Oct 29, 2011 | Sega Genesis 2 Console
Missing the part that plugs from console to television where do i find?
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Sega Genesis Console
I have two CD expansion consoles won't come on
"I have two CD expansion consoles and can't get the led to light and it doesn't seem to have any power at all. I have 3 Genesis mod 2 that work with my good cd console and hooked each up and get nothing with either one."
Which CD expansion do you have? There was a model 1 and 2. Either case, both have fuses that keep the system from powering on at all, they are marked on the board as F1, and ought to be near the power input. These go out all the time, and it's a common problem.
I repaired mine by using a fuse holder from auto zone, so if it ever goes out again I can easily replace it and skip any soldering.
Apr 22, 2010 | Sega Genesis Console
Power Problem
um take it back
Feb 22, 2009 | Sega Genesis Console
Sega not working no matter what.
Does it power up,,if its just not playing the games,, take some quetips and dip them in alcohol,,use it to clean inside the genesis where the games go in and clean the games with it,, if you have the sega cd addon system ,,also clean the place on the side where u connect the sega cd,, hope this helps,,i have 4 or 5 sega genesis,, and the sega cd system,,,thanks
Oct 05, 2008 | Sega Genesis Console
Sega Mega-CD Console Logo
60 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
