Question about Haier 2.0 Ton Multi-position Air Handler Hb2400vd2m20 Air Conditioner
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there was a green to orange hooked together and 2 blue wires that also were all ready hooked together from the warehouse and also there is a red, green, brown, white and another blue wire.. exactly how do I run these wires to stat??
  • 24 Answers
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Posted on Oct 20, 2013
Testimonial: "well I hooked it up like you said before I posted this and the stat does not come on.. so I thought maybe it had something to do with orange and green being together that wasn't it either, I am getting 24volts but nothing is showing on stat its a digital and tried another stat and still no change. so I was wondering maybe it came with a bad board.. what are your thoughts?"
5 Suggested Answers
carldc3
  • 82 Answers
SOURCE: installed a new honeywell thermostat blows fan but will not heat
make sure jumper is installed between rh and rc
Posted on Feb 08, 2009
konzzz
  • 255 Answers
SOURCE: pulled was pulled from my unit
actually 3prong plugs consist of ground, live and neutral.look for the label at the terminal of the plug.the GND means ground.
Posted on May 28, 2009
  • 25 Answers
SOURCE: type of wire needed for 60 amp upgrade
Got to use the 75 amp rating. otherwise you risk buring up your wires from over amping, fire, blowing fuses continiously, and breaker tripping. Not to mention possible damage to unit.
Posted on Jan 27, 2010
Testimonial: "I thought so...thank you"
markmezo
  • 15 Answers
SOURCE: The wiring neutral (white) and
Well in the UK & Europe, AUS & NZ, the black wire is neutral.
Any other colored wire (except green) is know as live/active/hot.
Use a tester, one touching the metal casing or earth & the other to see if the wire is hot/live/active.
Mezo.
Posted on Jun 08, 2011
Howto hook up th8320R1003 to heat pump
Byron, unless you have thoroughly familiarized yourself with the terminal designations on all three components, t-stat, air handler and heat pump you shouldn't attempt connection of the control. There are many variations of what will work and many more variations of what will NOT work.
No mention of outdoor sensors, so fine tuning of the electric heating stages to match the heat loss of your house (for most efficient operation) doesn't sound possible.
I know, this answer didn't help but there is no simple answer without having all the components in hand.
Mar 05, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Outdoor AC unit runs for about 2 minutes after air handler shuts off
Hello, it is possible that the new thermostat has some type of time delay built in it. But typically this would shut of the outdoor unit first and then the air handler.
Jul 25, 2012 | Heating & Cooling
I would like to know how to connect my central air unit, and heater to the honeywell Heat/cool Thermostat. I have two red wires, a green wire,and a white wire.
You have a problem.... two red wires....
The white goes on the "W" terminal
The green goes on the "G" terminal
Now... the red wires...
One goes to the outdoor A/C unit and the other is the power coming from the transformer on the air handler or furnace...
So, you need to figure out which wire has the 24v coming through it and hook that to the "R" terminal...
Then hook the other wire... the one that goes to the Y in the furnace to the "Y" terminal on the t-stat...this will continue on to the outdoor unit....
Becareful... if you hook the red wires up backwards you could blow the transformer or at least the fuse on the board if it has one...
heatman101
Sep 13, 2011 | Honeywell Heat/Cool Thermostat
I would like to know how to wire honeywell dt90e thermostat which wires where i have 5 wires from wall
It helps to know which wires went to the terminals on the old thermostat, if it had one. Otherwise, you would really need to know how they are hooked up inside the furnace/air handler. Some technicians hook them up differently, but I can give you the basics and most commonly used wires. R terminal- red/power wire G terminal- green/ fan wire Y terminal- yellow/ cooling or condenser wire W terminal- white/ heating wire C terminal- blue/black/ common or ground wire If you have a rc/rh terminal, they are usually jumpered with a small wire and your power wire still hooks to that. Hope this helps and good luck!
Jun 25, 2011 | Honeywell Heat/Cool Thermostat
The display on my honeywell thermostat is blank, what do I do
Hi, Check the batteries and replace as needed or check for power from the air handler/ furnace...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 18, 2010 | Honeywell Programmable Thermostat Heater
RTH221 honeywell thermostat install, hooked up blue wire from old thermo that hooked to C to o/b connection on new thermostat no work did I screw something up as old thermo will not work as well now. was...
maybe a blown fuse if it has one... if not then you blew the transformer...
Check on the circuit board in the furnace or air handler for a fuse...
if there isn't one... then you will need to replace the 24v transformer... they blow very easily...
heatman101
Aug 05, 2010 | Honeywell Heating & Cooling
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
T8411r1028 honeywell thermostat blank screen where would fuse be?
That thermostat should get power from 24V side of a transformer in the air handler. There should be a fuse in there on the PCB, but just as likely, there may be a 2-wire sensor in your drain trap that will shut it down if it senses water backing up in the drain piping. Clear that line from the outside of your house with a shop vac, cycle the breaker for the air handler if needed. You may also be low on freon, though, so a service call might be a good idea anyway.
Jun 01, 2009 | Honeywell Programmable Thermostat Heater
Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Dec 02, 2007 | Heating & Cooling
Haier 2.0 Ton Multi-position Air Handler Hb2400vd2m20 Air Conditioner Logo
126 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
