Question about Photography
Westinghouse troubleshooting CD Error. The two small rectangles in the lower left of the display window are lit.
4 Suggested Answers
  • 78 Answers
SOURCE: the display isnt working
It sounds like the flexible pcb has snapped and will need to be replaced
Posted on Dec 24, 2007
  • 10406 Answers
SOURCE: A rectangle with sides parallel to the x-y axes
It would be "cheating" for anybody to do your "homework" from your computer-mathematics class, unless you submit your answer, saying that an EXPERT on FIXYA did all the work on your behalf.
Posted on Jun 04, 2009
  • 15 Answers
SOURCE: small black rectangle in upper left corner of toshiba 52hm85 dlp
Sounds like it is closed captioning coming up. I would go in and verify both your TV's and the Cable/Satellites closed captioning is off.
Posted on Mar 06, 2010
Error message on the console
Dear Sir>
The error 7 has 2 options:
1) Elevation motor a) lube the motor, gear, and bars, tight the connector very well b) adjust the potentiometer.
2) The display board has problem, adjust the reed switch see the diagram attached, clean, and tigh the connector very well.
Tight the ribbon cable from keypad, tight the connector from display board vs lower board.
after your fix it RUN the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 02, 2012 | Sportcraft Exercise & Fitness
How do I reset the compuer after oil change?
SWITCH THE IGNITION ON ENGINE OFF.REPEATEDLY PRESS SMALL BUTTON UNDER LOWER RIGHT SPEEDOMETER UNTIL OIL LIFE IS DISPLAYED.THEN PRESS AND HOLD THE SAME BUTTON FOR 10 SECONDS UNTIL THE REMAINING ENGINE OIL LIFE RESET MODE IS DISPLAYED.RESET PROCEDURE MUST BE CARRIED OUT WITHIN 30 SECONDS. PRESS SMALL BUTTON LOWER LEFT TACHOMETER TO DISPLAY RESET TO CONFIRM RESET PRESS SMALL BUTTON UNDER RIGHT SPEEDOMETER. TO CANCEL RESET PRESS SMALL BUTTON LOWER LEFT TACHOMETER TO DISPLAY CANCEL THEN PRESS SMALL BUTTON LOWER RIGHT SPEEDOMETER.THEN SWITCH IGNITION OFF.
Mar 01, 2011 | 2008 Acura TSX
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
Westinghouse tv won`t turn on. blue light is lit
westinghouse flat screen ...blue light on lower part...can not get to stay on tv and no sound...what button so i push to go back to tv
Feb 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Integral of sinx how to calculte in casio fx991 es
Configure the calculator to be in MathIO : [SHIFT][MODE][1:MathIO].
Press the Integral key, the one judt beloe the [ALPHA] key.
The template of the integral appears, with the cursor in larger rectangle. Enter the function the screen displays the integral, a small upper sqaure, and a small lower square. The left parenthesis of the function is already supplied by the calculator.
Press [ALPHA] X to enter the argument of the function.
Press the right parenthesis.
Remain the limits.
Use left arrow to move the cursor just before the s of sin and press down arrow to enter a numerical value for the lower limit.
Press the up arrow to move cursor in upper square.
Key in the numerical value of the upper limit.
Press [=].
Warning. To have meaningful result, make sure the angle unit used is conform to the problem you are trying to solve.
Hope it helps.
Nov 01, 2009 | Casio FX-300MS Calculator
I dont get streo sound from my front left and
On the front LCD display of the receiver their is a small button for speakers A & B, make sure they are both lit. If they are, post a comment and I will help you troubleshoot further
Jun 29, 2009 | Audio Players & Recorders
A rectangle with sides parallel to the x-y axes and its left-lower corner at (0, 0) is being painted. The rectangle may be thought of as a flat-screen display with almost infinite resolution; initially the...
Apr 14, 2009 | Microsoft Windows XP Professional With...
How to enter variables
When you press the key between X^2 and log it gives you a template where you enter the base of the power (bigger rectangle) and the exponent (the smaller raised rectangle) . Using the 3 cubed exemple is not good because base and exponent are the same.
Exemple :15 cubed.
Press the key with an X with a small raised rectangle. The cursor blinks at the left side of the raised rectangle. Enter the exponent (3). Then use the left arrow to move the cursor to the base. Enter 15 and press [=]. The result is displayed as 3375 or in some other equivalent form (with a power of ten.)
Hope it helps.
Feb 23, 2009 | Casio FX-115ES Scientific Calculator
Printer not working - unknown error message
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
The display isnt working
Dec 24, 2007 | Pioneer DEH-P680MP CD Player
Photography Logo
79 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
