Question about Bussman Cooper BP-SSU On/Off Switch Box Cover
Bp-ssu installation - Bussman Cooper BP-SSU On/Off Switch Box Cover
Serial video cable driver for linux
Hey Anonymous! Unfortunately, the SSU-100 Single RS-232 Serial Adapter is only 'officially' supported on the following Operating Systems:
Windows 2000, Windows XP, Windows Vista, Windows 2003
To the best of my knowledge, there is not a Linux porting of the drivers.However there is a Linux driver package for the Quatech ESU2-100 (see below)
http://www.quatech.com/ManualsDriversFirmware/Communication/serqt_usb2_2.6_1.00.tar.gz
I doubt they are interchangable.
May 24, 2014 | Quatech SSU-100 Serial Adapter
Hi,I dont have any catalogues in my app manager and when i open my app manager this error is shown"operation failed".I flashed my mobile 4 times but ..... please help me
1. Make sure you have an active internet connection before updating the catalogs.
2. Go to Menu (top left icon on your desktop) -> "Application Manager", tap on top of the screen to open "Application Catalogs"; make sure you have the desired catalog(s) enabled.
3. If no catalogs are displayed, you may add them manually
Application Catalogs -> New
Catalog name: Nokia Applications
Web address: https://downloads.maemo.nokia.com/fremantle/ssu/apps/
Distribution: ./
Components:
-> Save
Catalog name: Nokia System Software Updates
Web address: https://downloads.maemo.nokia.com/fremantle/ssu/mr0/
Distribution: ./
Components:
-> Save
Catalog name: Extras
Web address: http://repository.maemo.org/extras/
Distribution: fremantle-1.3
Components: free non-free
-> Save
-> Update
Mar 04, 2011 | Nokia N900 Smartphone
My 1f82-51 thermostat has no display so heat nor air is working
Change the battery if the thermostar has them. If not then the 24 volt circuit may not be working from the furnace. Does the furnace have 110 volts to it. Are the breakers all on.. Is the SSU at the furnace turned On if it has one or is the fuse in the SSU OK. If all of this is OK then try a quick test. Take the Thermostat off of the subase and put a jumper wire from R to G if the blower comes ON then the thermostat may need to be replaced...... This process will work for any type of thermostat that is acting up... Hope this helps
Jan 31, 2011 | Heating & Cooling
Not charging video will not eject
CANON MV630I battery Specs:
  • Cell Type : LI-ION
  • Volts : 7.4V(Compatible with 7.2V)
  • Capacity : 4400mAh
  • Average Run Time :2-4 hours(minimum)
  • Color : GREY
  • Dimension : 55.10x38.20x39.90mm
  • Net Weight : 146.00g
  • Cpmpatible Model:
  • canon 5797a007, canon 5797a010, canon bp-508, canon bp-511, canon bp-511a, canon bp-514, canon bp-522, canon bp-535, canon pc511, canon vcn009, canon vcn009s, cta db-bp522, delkin dd/bp522, duracell drc522, empire bli-193-2.4, energizer er-c600, gp vcl008, hahnel hl-522, hama 46810, hama cp-810, optex li36, polaroid pr-522l, rayovac rv5462, sakar bp-522cl, sunpak hl-522s, techcell l522us, vivanco bp-22672decf09.jpg
    Jul 22, 2010 | Canon MV630i Mini DV Digital Camcorder
    Usb2.0 to rs232
    Quite often these do not need drivers and may just show up in your hardware list as an extra com port. The may also be listed in your usb hardware list.
    But if that is not the case with you then here it is
    Aug 24, 2009 | Quatech SSU-100 Serial Adapter
    I need a model:SSU-S0061(SSU-S0061-1B) I.T.E Power Supply For my tv to have power and work.
    Hello, I come from Shenzhen, China, I have you need the power of this model(SSU-S0061-1B). Please contact me. MSN:ttxiangtao@hotmail.com
    Apr 23, 2009 | SVA-USA VR-30W 30 in. LCD Television
    Using ICD-P210 and BP-150, use same software?
    I borrowed Sony Voice Editor 3 (version 3.0) from a colleague and can now download and play both the P-210 and BP-150 with one program.
    Apr 23, 2008 | Sony ICD-P210 Digital Voice Recorder
    Bussman Cooper BP-SSU On/Off Switch Box Cover Logo
    114 people viewed this question
    Top Bussman Electrical Supplies Experts
    ken skalski
    Gene Haynes
    Are you a Bussman Electrical Supply Expert? Answer questions, earn points and help others
