Question about 1998 Ford Explorer Thermostat Housing Cooling Outlet Kit for V6 4.0L
Replacing LH. Balance shaft and jack shaft timing chains. tensioners and guides.was turning over by hand to get it TDC . turned it over a few times before I think I got it right. how if I turn it over just before TDC it feels like its hanging up on something. was wondering if I could have bent a value turning it by hand. RH cam was still tight because wasn't changing that side.
  • 682 Answers
I wouldn't think that you could bend a valve by turning by hand. But if you put force on it, you definitely could. I know this doesn't help now, but I always get the timing marks close before removing anything, then when I line them up always turn forward or back just a little to get marks back in line. Never, never turn the engine over without a belt (or chain) on it.
Posted on Oct 20, 2013
Timming chain broke
place no 1 piston at TDC compression stroke. There are procedures for the timing of the balance shafts but if it is only the timing chain I will go to that
Align uniquely coloured chain link with intake camshaft sprocket timing mark-- INT--. ( this will be pointing at the 2 o'clock position)
install timing chain and sprocket as an assembly
align first matching coloured chain link crankshaft timing mark (5 o'clock position)
align the second matching coloured chain link with exhaust cam shaft timing mark--EXH ( at the 11 o'clock position
There is a special procedure to reset the balance tensioner and it is different to the timing chain procedure.
To reset cam shaft timing chain tensioner push piston fully and turn clockwise until locked
Once the tensioner has been compressed ensure the distance from end to end is 2.83 inches . If not repeat the resetting process
vehicles 30.000 miles the tensioner is released when the engine is first started . In vehicles over 30.000 miles manually release tensioner by tapping the plunger
Note cam shaft and crank shaft sprockets bolts MUST only be used once. If you want details on the balancer chain procedure then make a comment in the box
use tension wrench and a degree gauge
cam bolts are tensioned to 63 ft lbs + 30 degrees
crank shaft pulley is tensioned to 74 ft lbs + 75 degrees
Feb 02, 2014 | 2003 Saturn ION
2001 ford ranger 4.0 engine timing chain replacement
Hi Josiah:
According with the repair guide...4.0L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable Engine from the vehicle Oil pan Engine front cover Cylinder heads
  4. Lock the jackshaft tensioner by installing a pin.
    Jackshaft sprocket and chain assembly Left front cassette retaining bolt Cassette chain and tensioner assembly Rear jackshaft plug from the engine Right rear cassette retaining bolt and spacer Right rear cassette chain and tensioner Timing chain (s)
Fig. Remove the jackshaft sprocket-4.0L SOHC Engine 2000-2001
Zooming link for Remove the jackshaft sprocket-4.0L SOHC Engine 2000-2001
To install:
  1. Install or connect the following:
    Timing chain(s) Right rear cassette chain, tensioner and sprocket Jackshaft sprocket and chain on the engine and remove the tensioner pin
  2. Torque the jackshaft sprocket bolt in 2 stages:
    1. 32-35 ft. lbs. (43-47 Nm).
    2. Turn an additional 65 degrees.
  3. Install or connect the following:
    Cylinder heads Front cover Oil pan Engine to the vehicle Negative battery cable
  4. Fill the engine with clean oil.
  5. Start the vehicle, check for leaks and repair if necessary.
  2. With the vehicle in neutral, position it on a hoist.
  3. Remove the intake manifold.
  4. Remove the fuel supply manifold.
  5. Remove the accessory drive belt.
  6. Remove the thermostat housing.
  7. Remove the roller followers.
    NOTE You must retime the LH and RH camshafts when either camshaft is disturbed. Turn the crankshaft clockwise to position the number one cylinder at top dead center (TDC).
    NOTE The special tool must be installed on the damper and should contact the engine block to position the engine at TDC.
  8. Install the special tool.
    NOTE The right-hand camshaft sprocket bolt is a left-hand threaded bolt.
    NOTE If necessary, use camshaft gear torque adapter to loosen the camshaft sprocket bolt.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 08, 2011 | 2001 Ford Ranger Regular Cab
Setting of timing chains
Get Ford timing tool kit, part = otc-6488 (For about $119 USD on eBay)
4 timing chains (3 front including the optional balance shaft chain + 1 back)
2 cam guides (1 front + 1 back)
2 oil tensioners (1 front + 1 back)
1 jackshaft tensioner (1 front)
1 jackshaft guide/cassette (1 front)
1 balance shaft tensioner (1 front) (will probably be ok, so dont replace it)
1 balance shaft guide (1 front) (will probably be ok, so dont replace it)
new sprockets + bolts + gaskets etc.
new spark plugs + throttle body cleaner + lithium grease spray + oil change
head gaskets
some of these parts (the front stuff) can be obtained as a primary timing chain rattle noise kit Part# = 2u3e-6d256-** ab for 4*4 & bb for 2*4.
The kits also have later part numbers for us$ 76 @ http://www.fordpartsonline.com
My parts order (without the balance shaft stuff) was:
$76.04 KIT-TENSIONER TIMING 2u3e-6d256-ab
$47.93 Engine, Camshaft and timing, Timing chain, TIMING CHAIN, Explorer, Mountaineer, Rear - 4.0L SOHC - 4.0L SOHC
$57.36 Engine, Camshaft and timing, Chain guide, CHAIN GUIDE, Explorer, Mountaineer, Jackshaft To Cam - 4.0L SOHC - 4.0L SOHC
$103.22 Engine, Overhaul gasket set, OVERHAUL GASKET SET, Explorer, Mountaineer, Upper (Valve Grind) - 4.0L SOHC - 4.0L SOHC
$28.93 Engine, Camshaft and timing, Tensioner, TENSIONER, Explorer, Mountaineer, Upper - 4.0L SOHC - 4.0L SOHC
Its worth mentioning that this procedure is not enjoyable at all and should be undertaken with at least 8 full days to completion (I recon you could do it in half the time the second time).
It is basically on entire engine re-build with both heads off and the engine out of the vehicle.
It is not possible to do the rear chain or sprocket with the engine in the car as the flywheel needs to come off + at least 1 head, but it is possible to do the front primary chain and or front cam chain with the engine in the car.
You will be a ford exploder and timing expert after you do this - the main reason should be the love of your American built vehicle. Its a solid car - except for the plastic guides!
Disclaimer Note: This is how i successfully did the job, but i am not a ford mechanic and don't hold me responsible if this does not work for you.
Timing Overview
A Small Sprocket on the crank turns a larger (2 to 1 ratio) jackshaft sprocket that is in turn connected front & back to the 2 camshafts.
Thus a 360o turn of the crank will turn both the camshafts 180o.
Firing order is 1-4 2-5 3-6, Right side numbers 1,2,3. Left Side = 4,5,6.
At TDC pistons 1 & 5 are fully raised, thus 1 is about to spark & 5 is evacuated.
The engine will turn freely (no piston to valve contact) with the cams 180o out, it will even run (roughly) with 1 out 180o, any other settings may cause major damage to the valves.
The 2 cam shafts come with timing markings, "yes" real timing marks that anyone can use (even without special tools) to ensure correct timing.
The way to time it is to ensure both the off centre cam shaft slits are level/flat with the head.
With the engine at TDC both the cams need to have the off centre slot in the same position either up and level or down and level.
It is super critical that both the camshafts are 100% in sink with each other, i.e. not a few degrees off, the engine computer can compensate for crank timing but not engineering failure.
Be warned the camshafts can turn easily fast & hard by themselves as a few springs are compressed at TDC, I got my finger jammed and its still healing + if the engine is not at TDC you may damage a valve.
Now heres the hard thing that you will need special tools for - if you need to change the timing, you will need to be able to undo the cam sprocket bolt on both cams & these are done up real tight.
There is a tool that you attach that has 2 pencil thick shafts that fit into the sprocket and prevent it from turning - then you need to put about 90Nm of force on the bolt (remember the rear one if LHT)
For the $money$, its well worth getting yourself the tool kit - it will save you hours in the long run. Search eBay for otc-6488 should be US $119 - then sell them again for say $100.
There is also a tool version of the oil tensioner in the kit that screws right in and puts the correct amount of force on the chain + guide, to enable you to do up the cam bolt with the chain and sprocket in the right spot on the cam.
Dec 20, 2010 | 2003 Ford Explorer
Timing belt is broken is a belt or chain
chain. R&R instructions from autozone.com pasted below. let me know if you have any more questions.
REMOVAL & INSTALLATION
SOHC Engine See Figures 1, 2, 3 and 4
  1. Disconnect the negative battery cable.
  2. Remove the timing chain front cover.
During timing chain and sprocket removal, position the crankshaft 90 degrees past Top Dead Center (TDC), to make sure the pistons will not contact the valves upon assembly.
  1. Carefully rotate the crankshaft clockwise so the timing mark on the crankshaft sprocket and keyway align with the main bearing cap split line (90 degrees past TDC).
  2. Remove bolts, then remove the timing guides and tensioner.
  3. Remove the camshaft sprocket bolt, using a 7 / 8 in. (21mm) wrench to hold the camshaft. Then remove the timing chain and camshaft sprocket. Remove the crankshaft sprocket, if necessary.
To install:
  1. Inspect the chain for wear and damage. Check the inside diameter of the chain, it should be no more than 16.77 in. (426mm). Inspect the chain guides for wear or cracks and the timing sprockets for teeth or key wear. Replace components as necessary.
  2. Verify that the crankshaft is positioned 90 degrees clockwise past TDC from the keyway (keyway at 3 o'clock).
  3. Bring the camshaft up to No. 1 TDC by loosely installing the sprocket and rotating the sprocket until the timing pin can be inserted. The camshaft contains wrench flats to assist in turning the shaft. The dowel pin should be at 12 o'clock when the camshaft is at TDC and a timing pin ( 3 / 16 in. drill bit) should then install at about the 8 o'clock position.
  4. If removed, install the crankshaft sprocket, then rotate the crankshaft counterclockwise 90 degrees up to No. 1 TDC (keyway at 12 o'clock).
  5. Position the chain under the crankshaft sprocket and over the camshaft sprocket. If necessary remove the camshaft sprocket, then slide the camshaft sprocket into position with the chain already engaged. The timing chain should be positioned so that one silver link plate aligns with the reference mark on the camshaft sprocket and the other aligns with the downward tooth (at the 6 o'clock position) on the crankshaft sprocket. The letters FRT on the camshaft sprocket must face forward, away from the cylinder head and excess chain slack should be located on the tensioner side of the block.
  6. Temporarily install the timing pin to verify proper alignment of the camshaft and sprocket, then install and tighten the sprocket bolt to 75 ft. lbs. (102 Nm). Again, use a wrench on the camshaft flats to hold the shaft in position while tightening the bolt. Do not allow the camshaft retaining bolt to torque against the timing pin or cylinder head damage will result.
  7. Install the chain guides with the words FRONT facing out. Install the fixed guide first and verify the chain is snug against the guide, then install the pivot guide. Tighten the bolts to 19 ft. lbs. (26 Nm) and verify that the pivot guide moves freely.
  8. Retract the tensioner plunger and pin the ratchet lever using a 1 / 8 in. No. 31 drill bit inserted in the alignment hole at the bottom front of the component. Install the tensioner and tighten the bolts to 14 ft. lbs. (19 Nm), then remove the drill bit.
  9. Make one final check to verify all components are properly timed, then remove all timing pins.
  10. Install the timing chain front cover.
  11. Connect the negative battery cable, start the engine and check for leaks.
Fig. Fig. 1: At 90 degrees past TDC, the crankshaft sprocket timing mark and keyway will align with the main bearing cap split line
Fig. Fig. 2: Exploded view of the timing chain and sprocket assembly-SOHC engine
Fig. Fig. 3: Insert the timing pin to ensure that the camshaft is at No. 1 TDC-SOHC engine
Fig. Fig. 4: When the camshaft is at TDC, rotate the crankshaft counterclockwise 90 degrees to achieve TDC
Nov 02, 2010 | 1997 Saturn SL
Head gasket got bent and I have replaced it . Now the problem I'm facing is how to set the crank shaft and the comshaft timing. I need the procedure for engine timing
Timing Chain & Gears Removal & Installation To Remove:
NOTE: Keep the cam chain away from magnetic fields.
  1. Turn the crankshaft pulley so its Top Dead Center (TDC) mark (1) lines up with the pointer (2).
  2. Raise and support the vehicle.
  3. Remove the front tires/wheels. Front undercar splash shield hnda_trk_crv_frt_under_splsh_shld.gif
  4. Remove the front undercar splash shield.
  5. Remove the drive belt.
  6. Remove the cylinder head cover (See section on Valve Cover).
  7. Remove the crankshaft pulley (See section on Crankshaft Damper). CKP sensor and VTC solenoid electrical connectors hnda_trk_crv_ckp_vtc_ele_conn.gif
  8. Disconnect the Crankshaft Position (CKP) sensor connector (1) and Variable Valve Timing Control (VTC) oil control solenoid valve connector (2).
  9. Remove the VTC oil control solenoid valve (See section on VTC Solenoid Valve).
  10. Support the engine with a jack and wood block under the oil pan. Ground cable and upper bracket removal hnda_trk_crv_grnd_cbl_uppr_brckt_rem.gif
  11. Remove the ground cable (1), and remove the upper bracket (2). Side engine mount bracket removal hnda_trk_crv_side_eng_mount_brckt_rem.gif
  12. Remove the side engine mount bracket. Timing chain cover removal hnda_trk_crv_timng_chain_cov_rem.gif
  13. Remove the timing chain cover bolts both from the front to the block and from the bottom to the oil pan.
  14. Remove the timing chain cover.
  15. Loosely install the crankshaft pulley. Compress the timing chain auto-tensioner hnda_trk_crv_compr_tim_chain_auto_tensnr.gif
  16. Turn the crankshaft counterclockwise to compress the auto-tensioner. Lock the timing chain auto-tensioner hnda_trk_crv_lock_tim_chain_auto_tensnr.gif
  17. Align the holes on the lock (1) and the auto tensioner (2), and then insert a 0.06 inch (1.5 mm) diameter pin (3) into the holes.
  18. Turn the crankshaft clockwise to secure the pin. Removal of the timing chain auto-tensioner hnda_trk_crv_rem_tim_chain_auto_tensnr.gif
  19. Remove the auto-tensioner. Removal of the timing chain guide B hnda_trk_crv_rem_tim_chain_guide.gif
  20. Remove the cam chain guide B. Removal of the timing chain guide A hnda_trk_crv_rem_tim_chain_guidea.gif
  21. Remove the cam chain guide A (1) and tensioner arm (2).
  22. Remove the cam chain.
Oct 11, 2010 | 2002 Honda CR-V
2005 f250 5.4 gas need to know specs for timing a diagram would be awesome
To Install:
  1. Install balance shaft drive gear onto the left camshaft.
  2. Install the camshaft sprockets and new bolts finger tight.
  3. Using a vise, compress the timing chain tensioner plunger.
  4. Install a retaining clip on the tensioner to hold plunger IN during installation.
  5. If timing chain copper links are not visible, mark 2 links on one end and 1 link on the other end to be used as timing marks.
  6. Install right and left timing chain guides. Tighten bolts to 89 in-lbs (10 Nm).
  7. Rotate the left camshaft until the timing mark is at the 12 o'clock position.
  8. Rotate the right camshaft until the timing mark is at the 11 o'clock position.
  9. Position the crankshaft using the special tool. Then remove the tool.
  10. Install the crankshaft sprocket with flange facing forward.
  11. Position lower end of left (inner) timing chain on the crankshaft sprocket. Align the copper (or marked) chain link with the timing mark on the outer flange of the crankshaft pulley. NOTE: Upper half of timing chain must be below the tensioner arm dowel.
  12. Position the left timing chain on the camshaft sprocket. The timing mark on the camshaft sprocket must be aligned between the 2 copper (or marked) chain links.
  13. Place the left timing chain tensioner arm on the dowel pin and install the timing chain tensioner and bolts. Tighten bolts to 18 ft-lbs (25 Nm). NOTE: Lower half of timing chain must be above the tensioner arm dowel.
  14. Position lower end of right (outer) timing chain on the crankshaft sprocket. Align the copper (or marked) chain link with the timing mark on the outer flange of the crankshaft pulley.
  15. Position the right timing chain on the camshaft sprocket. The timing mark on the camshaft sprocket must be aligned between the 2 copper (or marked) chain links.
  16. Place the right timing chain tensioner arm on the dowel pin and install the timing chain tensioner and bolts. Tighten bolts to 18 ft-lbs (25 Nm).
  17. Remove the retaining clips from the right and left timing chain tensioners.
  18. Verify alignment of all timing marks.
  19. Install crankshaft sensor ring on crankshaft.
  20. Locate index mark on balance shaft and mark corresponding gear tooth with chalk.
  21. Position balance shaft on journals. NOTE: It may be helpful to use an inspection mirror to view the marks timing marks.
  22. Align the chalk mark on the balance shaft with the camshaft timing mark.
  23. Install the balance shaft bearing caps in their original locations. Follow the tightening sequence as shown in the illustration. Tighten bolts to 89 in-lbs (10 Nm).
  24. Tighten the camshaft phaser sprocket bolts in the correct sequence using 2 steps, as follows:
    • Step 1-30 ft-lbs (40 Nm)
    • Step 2-tighten an additional 90 degrees
  25. Position the crankshaft keyway in the 11 o'clock position.
  26. Lubricate and install all camshaft roller followers. WARNING
    Engine front cover replacement procedure must be completed within 4 minutes or entire procedure must be repeated. Failure to do so may result in future leaks
Oct 07, 2010 | Ford F-250 Cars & Trucks
My balance shaft belt broke while I was driving. It stripped some of the teeth off the timing belt and Im pretty sure it jumped time. I need a diagram to show the timing marks and how to get it back in...
see diagrams from autozone.com. Cam sprocket has an "UP" label, but also 2 scribes on the sides to align to upper head surface. The critical part of the job is keeping tension on the side of the belt that is opposite from the tensioner as the tensioner is released onto the belt. The timing marks must be aligned when the job is done.
4256a1c.gif To install:
  1. Install the camshaft timing sprocket so that the UP mark is up and the TDC marks are parallel to the cylinder head gasket surface. Install the key and tighten the bolt to 27 ft. lbs. (37 Nm).
  2. Install the crankshaft sprocket so that the TDC mark aligns with the pointer on the oil pump. Install the spacers with their concave surfaces facing in. Install the key. If equipped, install the TDC sensor assembly back into position before installing the timing belt.
  3. Install and tension the timing belt. Use a 6 x 1.0 mm x 25 mm bolt threaded through the cam belt tensioner plate to temporarily hold the tensioner.
  4. Temporarily install the crankshaft pulley and rotate the crankshaft counterclockwise 5-6 turns to be sure the belt is properly seated.
  5. Set the No. 1 piston at TDC for its compression stroke.
WARNING If any binding is felt when adjusting the timing belt tension by turning the crankshaft, STOP turning the engine, because the pistons may be hitting the valves.
  1. Rotate the crankshaft counterclockwise so that the camshaft pulley moves only 3 teeth beyond its TDC mark.
  2. Loosen, then retighten the temporary cam belt tensioner bolt.
  3. If the rear balance shaft sprocket/gear case assembly was removed, perform the following:
    1. If the rear balance shaft was moved, rotate the balance shaft until the 6 x 1.0mm x 100 mm bolt can be installed into the maintenance hole to the scribed line.
    2. Align the notch of the balance shaft sprocket edge with the pointer on the gear case. Install the rear balance shaft sprocket/gear case assembly using a new O-ring coated with fresh engine oil. The balance shaft sprocket should be installed in the TDC position. The pointer on the gear should align with the pointer on the oil pump housing plate.
    3. Tighten the mounting bolts to 18 ft. lbs. (25 Nm).
  4. If the front balance shaft sprocket was removed, perform the following:
    1. Install a suitable and sturdy screw driver or drift through the maintenance hole in the shaft behind the sprocket to hold the front balance shaft.
    2. Install the front balance shaft sprocket and mounting nut. Torque the nut to 22 ft. lbs. (29 Nm).
  5. Make sure the balance shafts and crankshaft are in the TDC position.
  6. Remove the crankshaft pulley, and if removed, install the balance shaft belt drive sprocket.
  7. Install the balance shaft belt, making sure the balance shafts and sprockets are still in the TDC position.
  8. If removed, install the balance shaft belt tensioner and tension the balance shaft belt.
  9. Loosen, then retighten the tensioner adjusting nut to 33 ft. lbs. (45 Nm).
  10. Remove the 6 x 1.0mm x 100mm rear balance shaft holding bolt.
  11. Temporarily install the crankshaft pulley and rotate the crankshaft 2 revolutions counterclockwise, stopping at TDC.
WARNING If any resistance is felt, stop immediately and determine the cause.
  1. Recheck that all of the TDC marks align for both the camshaft and balance shafts.
  2. Loosen, then retighten the tensioner adjusting nut to 33 ft. lbs. (45 Nm).
  3. Remove the 6 x 1.0 mm x 25 mm bolt used to secure the camshaft timing belt tensioner.
  4. Remove the crankshaft pulley and install the lower cover.
  5. Install the crankshaft pulley, lubricate the bolt threads and both sides of the crankshaft pulley bolt with fresh engine oil and tighten the crankshaft pulley bolt to 181 ft. lbs. (245 Nm). Do Not use an impact wrench.
See Figures 19 and 20
              Fig. Fig. 19: Holding the rear timing balancer shaft-4-cylinder Odyssey
            Fig. Fig. 20: Aligning the front timing balancer shaft-4-cylinder Odyssey
            1. Install the upper timing cover and the valve cover. Be sure the seals are properly seated.
            2. Install the side engine mount. Tighten the through-bolt to 47 ft. lbs. (64 Nm). Tighten the mount nut and bolt to 40 ft. lbs. (55 Nm) each.
            3. Remove the floor jack.
            4. Install and tension the alternator belt.
            5. Install the power steering pump and tension its belt.
            6. Install the splash shields.
            7. Reconnect the positive and negative battery cables. Enter the radio security code.
            8. Check engine operation.
            Sep 20, 2010 | Honda Odyssey Cars & Trucks
            LH guide is straight RHguide is curved has 3=8 slot on top to adjust has springloaded =hydralicassistfd tensioner below RH there is no adjusting screw and you cant get to anything whenfront cover is...
            To install:
            CAUTION Before installing the timing belt, confirm that the No. 1 cylinder is set at the TDC of the compression stroke.
            1. Remove both cylinder head covers and loosen all rocker arm shaft retaining bolts.
            The rocker arm shaft bolts MUST be loosened so that the correct belt tension can be obtained.
            1. Install the tensioner and the return spring. Using a hexagon wrench, turn the tensioner clockwise and temporarily tighten the lock-nut.
            2. Make sure that the timing belt is clean and free from oil or water.
            When installing the timing belt align the white lines on the belt with the punchmarks on the camshaft and crankshaft sprockets. Have the arrow on the timing belt pointing toward the front belt covers.
            A good way (although rather tedious!) to check for proper timing belt installation is to count the number of belt teeth between the timing marks. There are 133 teeth on the belt; there should be 40 teeth between the timing marks on the left and right side camshaft sprockets, and 43 teeth between the timing marks on the left side camshaft sprocket and the crankshaft sprocket.
            1. 1986-87 Engines:
              1. Using a hexagon wrench, loosen the tensioner lock bolt, set the tensioner and then slowly turn the tensioner clockwise and counterclockwise 2-3 times.If the coarse tensioner stud has been removed, be sure to apply locking sealer to the threads before installing it.
              2. Tighten the tensioner lock-nut to 32-43 ft. lbs. (43-58 Nm). Tighten the rocker arm shaft retaining bolts (in 2-3 stages) to 13-16 ft. lbs. (18-22 Nm).Before tightening, be sure to set the camshaft lobe at the position where the lobe is not lifted.
              3. Install the upper and lower timing belt covers.
            2. 1988 Engines:
              1. While keeping the tensioner steady, loosen the lock-nut with a hexagon wrench.
              2. Turn the tension approximately 70-80 degrees clockwise with the wrench and then tighten the lock-nut.
              3. Turn the crankshaft in a clockwise direction several times and then slowly set the No. 1 piston to TDC of the compression stroke.
              4. Apply 22 lbs. of pressure (push it in!) to the center span of the timing belt between the right side camshaft sprocket and the tensioner pulley and then loosen the tensioner lock-nut.
              5. Using a 0.0138 in. (0.35mm) feeler gauge (the actual width of the blade must be 1 / 2 in. thick!) positioned as shown in the illustration, turn the crankshaft clockwise ( slowly! ). The timing belt should move approximately 2 1 / 2 teeth. Tighten the tensioner lock-nut, turn the crankshaft slightly and remove the feeler gauge.
              6. Slowly rotate the crankshaft clockwise several more times and then set the No. 1 piston to TDC of the compression stroke.
              7. Install the upper and lower timing belt covers.
            Sep 18, 2010 | 1988 Nissan King Cab
            Timing alignment for 2200
            put it on tdc
            and go from there
            tdc top dead center
            May 09, 2010 | 2001 Chevrolet Cavalier
            1998 Ford Explorer Thermostat Housing Cooling Outlet Kit for V6 4.0L Logo
            53 people viewed this question
            Top 1A Auto Parts Vehicle Parts & Accessories Experts
            Tom
            Mike Stager
            Mike Stager
            Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
