Question about Samsung RFG293HARS
Water going in my vegetables tray - Samsung RFG293HARS
  • 2,113 Answers
That means the tube that drains your freezer compartment when defrosting is blocked. put a pipe cleaner or other down the funnel looking drip drain in the rear of the fridge. (on some models I don't know that particular model)
Posted on Oct 20, 2013
Water collects in vegetable tray of Samsung model SR-L09EVSS, purchased 29 November 2008 @ HIFI Corporation. Water collects daily, causing vegetables to become soggy, requiring daily moppinng up .
Buy designer lehenga
http://www.kartohome.com/buy-designer-lehenga
Buy designer lehenga in kolkata, Buy designer lehenga in india, Buy designer lehenga in noida, Buy designer lehenga in mumbai, Buy designer lehenga in banglore, Buy designer lehenga in delhi , etc.
Jan 01, 2017 | Samsung Refrigerators
Why my fridge is leaking water under the vegetables tray ?
at the back of the veg tray there should be a small drain hole , it may be blocked
Aug 27, 2014 | Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
I have a model ET8CHKXKQ0 1 Whirlpool refrigerator and it keeps collecting water in the meat tray, the vegetable tray and under both vegetable trays. I have vaccumed under the frig., in the back and...
The drain in the freezer is clogging. When the defrost switches on, the backed-up ice thaws and starts dripping down into the fridge area.
Easiest is probably to turn off the fridge, let it thaw, then check the freezer drain to see if you can unclog it.
Otherwise, you have to pull out the bottom and back parts in the freezer (which will probably have some sort of ice frozen to them). Once you see the drain pan, get a turkey baster and flat head screw driver. You'll have to make a hole in the ice above the drain and squirt hot water until you hear it start draining. The drain hole is off center to the right in the drain pan.
Good luck
Mar 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water in bottom of refrigerator under vegetable bins.
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jun 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Water accumulation under vegetable drawer model KTRS22M
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Jun 17, 2008 | Refrigerators
Refrigerator has water underneath vegetable and fruit bis. It seems like an air flow situation
We found that the drainage for the defrosting was plugged. The water from the freezer drains from a hole that's on the top of the fresh food unit. There's a gutter that shunts the water to a tube that runs to a tray underneath the refrigerator. The tray was bone dry. So we unscrewed the gutter from the top of the fridge, and yes, it was plugged. Some Scrubby bubbles later, the plug was done. We reinstalled it, and now we don't have water underneath the vegetable/fruit bins.
This is for the GE TBF15DC For other models, your mileage may vary.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Samsung RFG293HARS Logo
47 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
