Question about Maytag Refrigerators
MTG1950GR Maytag water puddling in bottom of fridge
  • 3 Answers
This CAN happen (and usually DOES) when your fridge is in dire need of a COMPLETE thawing. You'll need 24 hours to store your perishables. Open doors and UNPLUG and let it thaw. You CAN hurry the process with a hair dryer, but be sure #1: you use standard precaution against electrical shock if dripping water enters your hair dryer, and #2: DO NOT overdo use of the hair dryer and melt platic parts that'll make you sorry. :)
Posted on Oct 25, 2013
4 Suggested Answers
  • 225 Answers
SOURCE: Water in Fridge
Hi gchives.
My own fridge had this problem and it turned out to be a blocked drain at the back of the fridge compartment, just below the cold plate. The water is supposed to condense on the plate and run down to a drip channel, and then through a tube onto the top of the compressor, where it evaporates.
On mine, the tube was blocked with gunge so the water spilled over onto the bottom of the compartment. I got a length of earth wire - the sort used for wiring UK domestic ring mains - and poked it down the tube to clear the gunge away. I then chased it through with some hot water and washing soda and it has been fine ever since.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge.
If they do not, please give me more details so I can try to help you further.
Cheers, D
Posted on Jun 30, 2008
aborcass
  • 2651 Answers
SOURCE: water puddle under fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 28, 2008
  • 14 Answers
SOURCE: Why does my water line shake on the back of the fridge?
Does it shake all the time
Posted on Feb 24, 2009
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
Maytag mbf2258xeq leaks but it's not connected to a water line. Where's the water coming from?
water is coming from condensation from the compressor coil. usually this will evaporate fast enough to not puddle on the floor. check the plastic line running down the back of the fridge to see that it's not broken or pulled out. while you have the fridge out, clean the coil by blowing it out with compressed air and clean the pan under the compressor as best you can. Hope this helps
Nov 30, 2011 | Maytag MBF2258XEW
I have a Maytag MSD2432GR side by side. I am finding water pooling in the bottom of the Refrigerator side, as well as finding periodic puddles in front of the fridge. What is the cause and how do I fix...
IT MAY NOT BE LEVEL. the fridge has condensation that builds up on it but usually evaporates. you may also have a pinhole size leak in the icemaker line behind the fridge.
Jan 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side fridge not connected to any water source stand alone system except electricity. approximately 500 ml puddle of water underneath vents are clean but unsure where water is coming from...
This is what it sounds like to me. The defrost system melts away the frost in the cooling coils every 6 or 8 hours. This water goes into a tray at the bottom of the freezer compartment. there is a drain spout in the bottom of the tray. The water then goes through that into a plastic drip pan. This sits behind the vent below the doors. While the fridge is running, the water evaporates out into the the room. If the pan is missing, or cracked for some reason, the water goes onto the floor.
And that's were the water is coming from. The Fridge is not broken.
With the model number of the fridge, probably located on a placard inside the fresh food compartment, or possibly the freezer compartment, you can order a new drip pan from a parts supply house for something like $25.00 The easiest thing to do would be to put in it's place an inexpensive aluminum pan of sorts. that usually will do the trick and save money.
I hope this helps,
Happy New Year,
Mark
Jan 01, 2011 | Maytag MSD2758G Side by Side Refrigerator
Puddle of water in front of fridge also icing up in the bottom of the freezer
Your drain line is cloged at the bottom of your freezer there is a hole clear that hole and you should be good
Aug 04, 2010 | Maytag MZD2766GES Side by Side...
Water puddling in bottom of fridge. water is
If the water to the ice maker is off then the source would be the defrost drain. I have put together some instructions on how to clean out the drain so the water will go to the proper place. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 17, 2010 | Electrolux Refrigerators
Small puddle of water under fridge
if you have a thin sheet of ice in the bootom of the freezer your drain is clogged,use a hair dryer to lossen the ice sheet and get it out of the way,heat up the drain hole and pull the frig. out from the wall,use a hanger or something you can usr to clear the drain tube,last get a hot half cup water with alittle beach and pour it down the drain,your done,let me know how you do-ike
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Older maytag fridge side by side.
Buk, there's supposed to be a drain pan under your fridge to catch the water that comes from the drain tube. The water that's coming out is supposed to be there (only, it's supposed to be caught by the drain pan)... it's the water that's made when your fridge defrosts itself. If you plug the tube, the water will back up inside the fridge , puddle up in the bottom and eventually leak out through the door.
You should order a drain pan for it. Here's a link to one online. After you have it in place, you won't have to worry about it anymore. The water that collects there will simply evaporate back into the air.
Oct 15, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
