Question about K-Sun Corporation 2012xlst-pc - Label Ht Machine W/maxilabel each
Line over on the 2012xlst k-sun label maker - K-Sun Corporation 2012xlst-pc - Label Ht Machine W/maxilabel each
Is there a schematic for this label maker?
A new unit is about 89 dollars, the repair kit for one is 85. The kit would have the diagram. I don't believe it is feasible to get the kit instead of buying a new label maker.
Apr 15, 2016 | Monarch ® Pricemarker 1115 Two-Line...
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
Apr 10, 2014 | K-Sun Corporation BEE3FB - BEE3 LABELShop...
What is a label maker used for?
Label makers are used to develop the text design to print on labels.
For eg, in retail industries, they make labels(stickers) for printing Price tags along with item description and barcodes.
Label makers is a software which enables the user to frame their text position, fonts, description etc..! with which they their desired design in labels via a label printer.
hope we made u clear.
if you need info on label makers.
please see our site www.trridevlabelss.com
Jan 24, 2013 | Office Equipment & Supplies
HP Officejet J5780 All-in-One
your printing program needs a template, based on the label makers specs. That's usually what causes that, not the printer itself.
got backup?
Feb 12, 2008 | HP Officejet J5780 All-In-One InkJet...
RE: Dymo Letra Tag
If you use the "dynmo letratag 2000", just press the shift button (the green arrow button) and then the letter "N" (above that letter you should see the text "2=").
That will add a carriage return on your current position and the following text will appear on the second line when printed.
Nov 14, 2007 | Dymo LetraTAG Thermal Label Printer
K-Sun Corporation 2012xlst-pc - Label Ht Machine W/maxilabel each Logo
103 people viewed this question
Top K-Sun Corporation Office Equipment & Supplies Experts
jasbo
jasbo
Are you a K-Sun Corporation Office Equipment and Supply Expert? Answer questions, earn points and help others
