I would like to factory reset my computer - Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Boot to bios and reset it.
Posted on Oct 20, 2013
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
Any idea what's wrong diagnostic shows factory reset fail, as between 92/89
Usually on computer resets with factory specs. If they fail it is because of an internal problem. I work on many computers, mostly cars. When the factory reset fails it is because the computer your trying to reset, has a problem. When I trace it back to a main chip. I throw it away.
Dec 13, 2015 | Cars & Trucks
Resetting factory settings
try reset it in iTunes
Jan 11, 2014 | Apple iPhone 4S
Factory reset
Bro You Don't Need To Restore Factory Your Computer Just Renew Your Windows
It Will Automatically Reset The Factory Setting
Nov 06, 2013 | HP Pavilion zd8000 Notebook
Factory reset on my laptop
Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting. This utility is convenient because you're not forced to use the Windows startup CD to restore your computer.
Step 1: First backup all your important data and restart your computer.
Step 2: Press 'F8' if you are using Win7/Vista or 'Ctrl + F11' if you has Win Xp. 'Advanced Boot Option' menu options will be opened.
Step 3: Choose 'Repair your computer' from the 'Advanced Boot Options' from the menu and press 'Enter'.
Step 4: Select language setting and press 'Enter'. Now Login window will be appeared.
Step 5: Now login as administrator to continue the factory reset process.
Step 6: Click 'Dell Factory Image Restore' followed by the 'Next' button.
Step 7: Choose the check box marked 'Yes, reformat disk drive and recover system software to manufacturer condition'. Once the check box is chosen, simply select the 'Next' button and your Dell computer/laptop is renewed to factory setting.
Step 8: Press 'Finish' once it has been done. ...
This process will erase all your previous changes that have been made to the Dell computer and reset the configuration settings to factory setting.
Feel free to get technical assistance anytime at http://www.vtechsquad.com/dell-support/
May 26, 2012 | Dell Inspiron 1521 Notebook
How to master reset
Master Reset or Factory Reset
When Factory Reset is performed, the setup value will factory default setting
When initialization starts.
1.Select System Setup from Menu Screen.
2.From the System setup submenu, Set Factory Reset to ON
3.When you exit Menu, The phrase FACTORY RESET Appears on the monitor and
The Initialization starts.{ON/OFF} Use arrows UP-- DOWN & , kEY TO MAKE CHANGES
HOPE THIS HELPS
Oct 18, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
Hello, I have Toshiba P305D-S8900. My son was playing some games on the computer. The screen display automatically changed to really bright. I am not able to reset it no matter what I try. I uninstalled...
hold fn key and tap f8 decrease brightness
hold fn key and tap f7 increase brightness
last resort
to restore to factory defaults
turn off computer hold the zero key turn on computer
should boot to factory reset menu, this will erase your data
May 22, 2017 | Toshiba Satellite P305D-S8900 Notebook
Need to reset my acer computer to factory settings.
Hi! Try system restore first and check if that will remove the virus but if not then you can reset the machine to factory defaults by pressing ALT+F10 during start up or when the acer logo appears on your screen.Follow the prompts and you should be able to reset the computer to factory image.Make sure you back up important files because it will wipe the system clean.hope this helps...
May 29, 2010 | Acer Aspire™ T180 PC Desktop
Restore to factory setting
If you want to completely reset it back to the original windows settings you must re-format your computer. This won't put the original programs back on it that you had before, but it will give your computer a COMPLETE reset. Meaning also that if you want to keep some data you must put it on some external drive because your hard drive will be completely overwritten.
If you want to get it back to just the factory settings, you could try to contact their customer services if they don't anything on their site to help you, although I would not recommend it. Factory settings aren't the best because they usually put stuff on your computer that you don't really want. Re-formatting is the best thing to do.
Nov 09, 2008 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
