Question about Cell Phones
My iPhone 5 screen developes horizontal
My iPhone 5 screen suddenly developes horizontal & few vertical lines across it when left idle(looking whitish).But lines reduce after a wile when in use?...& I have turned it off & on severally??!Moreso these lines are there when d fone is just turned on as Wel...???!!!
Go to mobile shop and buy another one
Posted on Oct 20, 2013
4 Suggested Answers
STR8JCKTED
  • 42 Answers
SOURCE: samsung 340 cell phone
THIS WOULD PROBABLY BE AN INTERNAL PROBLEM YOU PROBABLY CANNOT FIX.SOME TYPE OF INTERNAL CONNECTION OR GROUND.YOU PROBABLY WILL NOT BE ABLE TO DO ANYTHING UNLESS IT IS UNDER WARRANTY
GOOD DAY
KZ
Posted on Feb 25, 2008
Bajanguru
  • 7752 Answers
SOURCE: MY NOKIA 6500 HAVE SOME UNWANTED LINES ACROSS THE SCREEN
Really I have never heard of a solution other than having the screen replaced
Posted on Sep 15, 2008
Fix-A-Fone
  • 50 Answers
SOURCE: Iphone display doesn't work after it dropped
You have broken the Liquid Crystal Display (LCD) the touch screen digitizer and front glass is a seperate unit so that is why it still works. The LCD is the visual part and can be purchased online and fitted yourself if you feel up to it and is not that expensive, Videos of how to do it also on youtube. Or you can take it to a mobile repair centre to get them to do it for you.
Posted on May 29, 2009
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sony FD Trinitron WEGA KV27FS100 horizontal lines across top part of screen
Check and replace all electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them to replace. Replace all at one time. The fault you describes here is technically known as 'vertical retrace lines'. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Sometimes, you might get some more details from there.
Oct 13, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
have a look at my tips for replacing the LCD screens on monitors, by clicking here....
Aug 11, 2010 | Dell Audio Players & Recorders
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Apr 15, 2009 | Televison & Video
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Cell Phones Logo
69 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
