Question about Frigidaire Dishwashers
Electrolux dishwasher latch - Frigidaire Dishwashers
  • Official Brand Answer
  • 4,342 Answers
Hi Nava, I am happy to assist you!
I'm not certain I understand your question or concern? What exactly is the issue your dishwasher is experiencing with the latch? Is the door not closely properly? Will the door not open? May I please have the model number? The serial tag is typically located on the right side as you open the door. With this information I can better address the issue at hand. Thank you!
Posted on Oct 23, 2013
I have replaced door latch because door was not clicking shut. It now clicks shut but dishwasher does not work. It does work however when door is closed but not clicked. Also works when door is open!...
I appreciate your post, Lorraine McGowan!
Based off the information you have provided you have provided your Electrolux dishwasher is not working properly when the door has been shut and clicked. From what you have described it sounds like your door latch, wiring harness, or control panel could be the problem. I would highly recommend contacting a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Feb 21, 2015 | Electrolux Dishwashers
The detergent door on my Aunt's Electrolux GLD9857AQ1 dishwasher doesn't latch. Is there an easy fix? I tried manually moving what appears to be the latch to make sure it wasn't just stuck, but that didn't...
Hi James Curry, thank you for your post!
From the information you have provided the detergent door is not latching on your Electrolux dishwasher. It could be possible that the door latch is broken or door strike is faulty. You may need to replace the latch I would recommend checking over each component to assure there are no cracks or broken pieces. If each appears to be in proper working order I would recommend having a professional technician come out to review and provide an accurate diagnosis. This will help to avoid any unnecessary part purchases. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Feb 06, 2015 | Electrolux Dishwashers
Electrolux dishwasher fdb2310lcc1 flashing cl on display
Hello sandy miller, thanks for your post!
From my understanding your Electrolux dishwasher is flashing "CL". Typically, that stands for close door it could be an issue with the control panel, door latch, or door strike. I would recommend having a professional technician come out to properly diagnosis your dishwasher to avoid any unnecessary part purchases. Hope this helps. -Matt
Nov 16, 2014 | Dishwashers
How to fix electrolux el 6115 door latch is faulty and doesn't click shut
It happens to skip latch and is no longer possible to close the door and turn on the dishwasher. The latch is in plastic material in which a system of levers provides the mechanical action.
Solution: Remove control panel and put latch back into normal position with the slot forward. Look the picture.
Dado
Jul 09, 2014 | Electrolux Dishwashers
Electrolux esl 6226 not working beeping sound and light flashing
Hello Eamonn, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 12, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
My electrolux dishwasher is showing warning lights and would not reset
Hello Ali Bilgrami - Try reprogramming the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit, confirmed that the door is properly latched and restart unit. If it proves to be ineffective, then the unit may possibly have more serious issues such as; wiring failure, faulty door latch assembly or control board. I would strongly recommend contacting a local professional for further diagnosis should all troubleshooting measures fail. You can often locate qualified services by visiting the manufacturer website.
Feb 24, 2013 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
Aug 07, 2012 | Electrolux Dishwashers
Electrolux Dishwasher no lights on panel
Check circut braker first then door latch , so are you saying no power at all at the unit ?
Dec 08, 2011 | Electrolux Dishwashers
Electrolux ewdw6505gs model dishwasher commd panel does not power
Read publication 5995509477 of Electrolux name factory Parts Catalog. You will see the POS NO 12 Part no 7154671401 name Latch Assembly, door w/shield. This relay stay open. a little bit of WD-40 and he working correctly.
Apr 22, 2010 | Electrolux EWDW6505GS Fully Integrated...
Dishwashers Logo
66 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
