SOURCE: Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
SOURCE: Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
