Question about Minolta Maxxum HTsi Plus 35mm SLR Camera
I just got batteries for this camera and when i turned it on it worked perfectly. i turned it off opened the back just to look at it then closed the back. when i switched it back on i got "err" on the screen. i dont know what happened.
  • 90 Answers
If there was a film in the camera and you opened the back, all the pictures you took got burned. You need to rewind the film take it out, put a new one in and try to turn on the camera. err should be gone.
Posted on Nov 05, 2013
Battary Popping out while clicking
look at the original battery and the replacement you have.. check the length and see if they are different.. the replacements may be a bit too long..causing the door to not close all the way..
Jan 12, 2014 | Nikon Coolpix L23 10MP Black Digital...
My digicam won't start
There could be a couple of reasons why your camera would not start.
Before considering it to be defective, verify that the camera has batteries inside and that these batteries are charged. To do this:
  1. Locate and open the battery compartment.
  2. Identify the type of batteries needed and purchase new ones OR
  3. Recharge the batteries with the recharger provided.
  4. Place the new/charged batteries inside, closing the battery compartment.
  5. Try to turn on the camera.
If the camera still doesn't work after verifying that the batteries are in order, remove the memory card and any other accessories that the camera may have and try turning it on again.
If still the camera won't turn on, one last step can be performed if and only if your camera uses standard batteries (AA or AAA). If this step is performed incorrectly, you could short circuit the batteries, which would discharge them. This procedure will not damage the camera if performed correctly. Please pay attention and do exactly as explained:
  2. Remove the batteries.
  3. Place the batteries back inside in the opposite direction than the one indicated. If the position indicated is for the positive end first, place the battery with the negative end first. Do this process for all the batteries.
  4. Close the battery compartment.
  5. Attempt to turn on the camera. It will not turn on, but this step is necessary nonetheless.
  6. Open the battery compartment.
  7. Remove the batteries.
  8. Place the batteries in the correct position according to the indication.
  9. Close the battery compartment.
  10. Attempt to turn on the camera.
If the camera still does not work, it is likely that it is defective. At this point you should take the camera to an authorized service center.
Mar 30, 2011 | Cameras
Camera will not take pictures and I can not see anything thru
Found this on another web site. Worked for me
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority (“Tv”).
Use the four-way button on the back to set the shutter speed to 15 seconds.
Press the shutter release. Count to seven, then pop open the battery compartment. (I discovered that the camera will beep when you do this.)
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
May 13, 2010 | Canon PowerShot S2 IS Digital Camera
DSLR do not power on
It's almost impossible to accurately troubleshoot a "dead" camera without seeing it, but your problem could be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Oct 20, 2009 | Pentax *ist DL Digital Camera
My camera is acting up
check the lens the lens might be closed if are open and hold for 5 seconds if it doesnt work take it to a specialist
Aug 07, 2009 | Olympus FE-170 Digital Camera
My Blackberry 8310 curves camera won't open
OMFG lol!. I just saw this on pinstack.com
My camera had hte same problem for months and this just fixed it!!
1)Remove back cover
2)Press gently, but firmly on lense (you should hear a click)
3)Battery Pull
Apparently if dropped at all, the camera can shift!!
Cheers, Imma go take some pictures after months of not being able to!
Jan 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Camera wont turn on, has Fresh batteries
Had the same problem, replaced the regular Alkaline batteries with NiMH rechargeables and it works. Must be something in the in camera battery settings. It still wont work with regular alkalines. Go Figure.
Jan 31, 2008 | HP Photosmart M525 Digital Camera
Kodak easy share digital camera
I have a kodak cx7430 that one day just wouldn't come on properly. All I got was a red light, no matter what batteries I tried. So I began to wonder if this was a ploy of Kodak's to get people to buy new cameras...I don't know if that's true, but I did find a little switch in the battery compartment that was open. I noticed I could close the switch with a pen tip, but it wouldn't stay closed, so I taped it closed with a piece of electrical tape...and guess what...THE CAMERA NOW WORKS PERFECTLY.
I don't know if this is true, but I heavily suspect that this switch opens after X amount of use... because I know 2 other people who's cameras have done the same thing...sooner with heavy use and longer with light use.... LOOK FOR THE SWITCH, TAPE IT AND TRY IT! Email me if it works for you admin@durhamdirectory.com
Jan 19, 2008 | Kodak Cameras
Sony DSC-S500
you are right it has defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 11, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Minolta Maxxum HTsi Plus 35mm SLR Camera Logo
49 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
