Question about Maytag PGR4410 Performa Gas Kitchen Range
Maytag performa range oven top
I'm trying to replace my thermostat and can't get the stovetop off to get to it, I tried turning the burners counter clock wise and they wouldn't turn
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
If there are any screws around or in the burners, they have to be removed first. Once all the screws are removed, use a blade to loosed the burner. Then try turning again.
if you do get it open, lift just an inch or two to make sure you are not stretching any gas lines. They will break then you will need a new stove.
Posted on Oct 20, 2013
huuum
  • 750 Answers
SOURCE: maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Posted on Oct 06, 2008
rickzilla
  • 706 Answers
SOURCE: circuit blows and when we get it back on the fault code says H3
Hello rcgrecco,
I will try to assist you but will be making some assumptions based on your problem description. First off, when you say it takes a few tries torest the fuses.. are you referring to circuit breakers? or changing out fuses a few time until it begins to work ok? In either case, the fact that it is drawing more current than the service ( fused or circuit breaker protected implies that you have one of two problems, 1. undersized service ( meaning the fuse of circuit breaker which protect the circuit is under-sized) or 2. a short internal to the stove or receptacle that supplies power to that stove.
I would approach a solution in this manner. Remove or disable power to the stove then open the wall receptacle and ( with power verified and off) tighten all wire junctions.. I have seen cases where a loose wire termination becomes resistive and then in order to meet power demand at the burner, more current is drawn which in turn causes the breaker or fuse to trip..) I would also check the terminations at the point of entry for the power cord at the stove. Make sure all the wire terminations are tight. Once you've done that, try turning on one burner at a time and see if the service remains on or trips the protector ( fuse/breaker) I wouldn't use the oven until I verified that each burner works OK.. then try the oven by itself.. and add a burner .. then two.. ( the point being is to try to determine if you have one of the heating elements shorting. 12:00 flashing is the default time setting after power is lost and restarted. I am almost 'questioning your electricians findings" since circuits do not trip unless there is a fault ( too much current being drawn or the service is under-sized for that oven) or... the circuit protection in and of itself is failing due to marginal components. The fact that it is getting worse suggests that whatever was shorting is shorting more frequently.. perhaps a heating element is shorting after it gets hot.. they are typically resistive elements and it is possible for a short to develop between the core material and the protective jacket.. I hope that helps you... or at least provides a few ideas on where to look...
Regards,
Rick
Posted on Feb 16, 2009
SOURCE: I was setting the clock
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Posted on Mar 05, 2009
  • 338 Answers
SOURCE: I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Posted on Mar 19, 2009
dmftrucker
  • 1922 Answers
SOURCE: Maytag Performa Electric Range (PER1510) tripped circuit breaker.
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Posted on Aug 23, 2009
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
I have a Maytag Performa gas stove. The burners on top work fine. The oven part glows when I turn it on, but it does not heat up. Is there a pilot light that I can light, or is this a completely...
The problem with the oven not lighting believe it or not is going to be that the igniter is weak and not drawing the correct amount of power to allow the gas to flow.I know it would seem since the igniter comes on that it could not be the problem yet since it comes on to me a oven technician with 30 years experience the igniter is exactly what it is.
GENE
Sep 25, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Nov 20, 2009 | Maytag PGR4410 Performa Gas Kitchen Range
Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
Oct 20, 2009 | Maytag MER5775Q Electric Kitchen Range
I was setting the clock on my maytag model # PER4311ACW stove/range and then a code "5 A6" popped up on the display and now the oven won't turn on altough the stovetop still works and the display...
Aug 09, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Maytag PGR4410 Performa Gas Kitchen Range Logo
98 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
