Question about Pool & Spa
Jandy service manual - Pool & Spa
  • 1,631 Answers
For what model heater?
Posted on Jan 29, 2014
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
Where can I download a free Jandy manual?
go to jandy website they have PDF manuals you can download for free if not email me i will help you out
Aug 28, 2014 | Pool & Spa
Jandy heater service manual
check power in if ok check transformer if ok check gas pressure if ok check safety circuit if when firing voltage to gas valve brown wire check ignitor
Nov 25, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
IT TURNS ON THEN SHUTS OFF,DISPLAY FLASHES SERVICE AGS
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 29, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
On the jandy 400 lt its displaying the AGS code... what does that mean?
AGS
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
Need a manual for Aqualink RS8
Thank you for posting your question here on Fixya.com.
http://www.jandy.com/html/productsupport/launchManual.php?url=AquaLinkRS_Owners_6593RevM.pdf should work. If not, or for older versions, contact Jandy direct at 1-800-822-7933, between the hours of 5:00 AM and 5:00 PM (Pacific time). Or, send an email message to service@jandy.com
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 12, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Service light and ags light comes on after a minute or two
I had this problem. Jandy ended up replacing the burner from day 1 with the heater (LT400 propane). It was a manufacturing defect. Of course it took 5 trips from the "warranty" company to not fix it before they finally punted to Jandy. Then, there's only one Jandy service rep from VA to ME (I'm in PA).
Jan 27, 2010 | Jandy Laars Lt 400,000 Btu Heater
Jandy Time Master manual
contact jandy tech support they will walk you through it
Jun 02, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
