Question about Senco Air Tools & Compressors
Determine model senco finish nail gun 89200503
  • 1388 Answers
SOURCE: senco finish nailer, drive pin
Senco nailers are very reliable however could suffer from several issues that would cause your problem. Here are a few things to check that may solve your problem. Bent driver, worn parts, broken check valve. Main problem with all finish nailers is bent driver blade. Easy to check, remove and examine. The driver should travel length of cylinder without jaming. Driver oring/plastic ring should fit snug into cylinder. Remove cylinder and check the oring neer the bottom of the cylinder. This is a check valve. There are small holes that should be cleaned. If oring is loose or broken just use any oring that fits snuggly. Next, check that lower bumper is not chipped or cracked and that washer under bumper is not too worn or missing. Replace parts as necessary. (
Posted on Dec 17, 2008
SOURCE: How to unload nails from Senco FinishPro 35
when you pull the spring back like your going to load it .put your finger in the hole and push it .you'll see that the nails will be release.
Posted on Jun 21, 2009
SOURCE: Senco nail gun was working one minute and then died...
gun nails frist nail then does not set next nail
Posted on Sep 02, 2009
  • 12 Answers
SOURCE: My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Posted on Oct 04, 2009
  • 2176 Answers
SOURCE: air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Posted on Oct 06, 2009
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Senco SFN30 15 Ga Finish Nailer Parts
Feb 16, 2017 | Senco Air Tools & Compressors
I have an older pro 18 serial number is 03c19425. It shoots with out pushing the safety in and not sinking nails. It leaves them about an 1/8 to 1/4 out. What do I do.
The Finish Pro 18 is a very good gun but I wouldn't spend more than $50 to fix it. You can get the newer FIP18mg for around $90 which includes a new warranty. If you really want to repair your gun:
Go to, click on the link 'Parts Charts/Specs/Manuals' at the top, scroll down to the Finish Pro 18 and open the parts guide. You are going to have to find out what parts of the safety element are broken or missing. As for the not driving nails all the way in, you have worn or broken o-rings inside the gun. The parts guide shows you need a Senco repair kit #YK0393. Senco no longer makes this kit but sometimes you can find them online at aftermarket retailers. Just Google or Bing 'Senco YK0393'. If you can't find one you can order all of the required parts from Senco but you have to order each one using part numbers from the parts guide.
Feb 16, 2011 | Senco Tools & Hardware - Others
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
How to load nails into the magazine
Hi. Here are pix that show u what to do.
be sure u are using senco headless nails and be sure the gun is upside down and that you load the nail row head first so the points are pointing out. J.
Jul 12, 2010 | Senco FinishPro 35 FinishPro 15 SLS15 3...
With the finish pro 35 can you use any 15 gauge strip of nails,glued or plastic strip
i believe that gun takes 16 gauge nails, and yes, all 16 gauge nails are the same, as long as they are strait, not angled
Mar 21, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
Clean the track and piston by removing nail tray (there are a couple of allen screws)and removing the gunk from the nail tape and if you have been shooting something glued that to. Remove head assembly and thoroughly clean and oil that also. that should fix you right up I have a couple of these guns and that is typical.
If that is no the problem rebuild the gun it is worth it as they are a great air gun
Hope this helped
Dec 15, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Gun will not drive pins flush with wood. Wood is
What is your air pressure setting. A finish nailer such as this usually requires 70 lbs to drive flush. Adjust air to this value and test fire in scrap. Keep adjusting air presure until nail drives flush.
Nov 23, 2009 | Senco 4N0001N Finishpro 11 23 Gauge Micro...
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Mar 28, 2009 | Senco Finishpro 15 Finish Nailer & Sls15...
Air Tools & Compressors Logo
Top Senco Air Tools & Compressors Experts
John Trevino
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
