Question about Health & Beauty
My tanning bed turns on but the tanning bulbs wont light up
  • howard dempsey
    howard dempsey Oct 21, 2013
    never mind i fixed it....switch was loose from the fan motor
SOURCE: tanning bed setup
HI a bought a tanning bed last night from a tanning salon it was hooked threw a phone line or something like that my hubby brought it home and hooked it up here .now i cant get it to work ,will i ever see it work and how can i get it to work for me.
Posted on May 28, 2008
  • 99 Answers
SOURCE: i have a 3200 montego
probably one of 2 things either
A) the bulbs need to be replaced (you can test this by swapping one that you know works and one that you know doesn't.
B) There may be multiple ballasts used to drive the lights.
(if you tried the first test and found both bulbs to be good then its a good indicator that the ballast is the problem)
Posted on Oct 10, 2010
Gophering
  • 187 Answers
SOURCE: i need a manual for a sunual 3200 tanning bed ,i
Try this link...
www.freemanualsonline.com
Kind regards!
Posted on Sep 13, 2011
skychief2001
  • 21873 Answers
SOURCE: sunquest tanning bed wont turn on after not being used for over a year?
you might want to post this in a different section to get an answer
Posted on Aug 17, 2012
emissionwiz
  • 76846 Answers
SOURCE: need a manual for esb 16 tanning bed free
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Posted on Oct 11, 2012
MY TAN BED WILL TURN ON BUT WONT LIGHT UP. COULD IT BE THAT MY 2/20 PLUG IS NOT STRONG ENOUGH?
No. DId you just get the bed? Are you sure it's 220V? what brand of bed?
Mar 15, 2016 | Health & Beauty
How to replace bulbs in tanning bed
Without the specifics of your bed, I can give you some general info.
  • The first thing you need to do is remove the acrylic. Depending what type of bed you have, this may require a screw driver to remove the metal retaining strip on the outside edge of the acrylic.
  • Set the acrylic aside, & remove the burnt out bulb(s).
  • Depending on the type of bulbs you are using, you may need to place adapters on each end (these can be removed & reused from your old burnt out bulbs).
  • Regardless of bed type, most have one thing in common when it comes to bulb terminals. One end of the bed will have a stationary terminal, & one end will have a springy one.
  • Place one bulb end in the spring side first, press in, & guide the other end into the stationary side.
  • Turn bed on for a test to make sure everything is working properly.
  • Replace acrylic (and retaining strip if necessary), and you're ready to tan :)
Jan 06, 2015 | Health & Beauty
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Tanning bed
Check the bulb you adjusted, you probably got it in wrong, and shorted stuff out. Reset the bulb, and replace the fuses. At least you had fuses.
Nov 30, 2013 | Remington S 1007 Tourmaline Straightener...
2 tanning bulbsdont work. could it be the fuse in the bed
maybe they burnt out. you can use an UV reader, which lets you know when to replace the bulbs. it tells you how much UV light is being outputted. When you replace your tanning lamps, it is ideal to replace them all at once.
look here for more info http://www.mastertanning.com/tips/23/tanning-lamps/
Feb 26, 2013 | Health & Beauty
Do I need to worry about how often salons change the bulbs in their tanning beds?
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
Feb 18, 2013 | Health & Beauty
My ESB tanning bed lights won't come on when turning on bed
my tanning bed comes on but wont light up
Jul 24, 2012 | Cars & Trucks
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
