Question about Canon Elura 100 Mini DV Digital Camcorder
Every time I try to play a tape, I get the message remove tape
  • Mona Littlejohn
    Mona Littlejohn Oct 21, 2013
    When I try to play, rewind, or fast forward a tape, I get the message "remove tape". t
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
Canon DM-XM2 Will not record or play back
Clean Idler unit it is magnetism and clean sensor it will work
Mar 08, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Bad playback
Please try to buy a head cleaning tape and put in your camera and play for three times..Then record a cassette and play,if you are not getting the picture replace the drum assy and check.
Oct 12, 2007 | JVC Cybercam GR-DVP9 Mini DV Digital...
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Reinsert tape message
I got the dreaded reinsert tape message today and i thouht that my video taping days were over. i then made my way to this page and saw this. whack it three or four times and it will work. at first i thought what a load of crap but i tried it anyways... being really mad at the time, i showed my camera no mercy. i took out the tape and gave it 4 hard hits with my palm, put the tape back in and it worked. thanks alot, this works
i
Aug 11, 2007 | Sony CCD-TRV138 Camcorder
Tape will not load
I have enabled the MV6i to load a tape by: replacing the 3V 'data' battery, re-entering the date and time, turning the camera off for about half an hour, after taking several photos using the photo function the tape would load properly. Hope this works for you too! jimtarver@ntlworld.com
Mar 07, 2007 | Canon MV6iMC Mini DV Digital Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
44 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
