Question about Citizen CT-S300 Printer
I have a CT-S300 POS printer using 3/8 ' wide paper . When I print the receipt it doesn't advance all the way to the tear off point (stopping short about 1/2 "). I have to push the feed button 2 time to get to the exact spot. I have tried turning it off then holding the feed button down then turning the printer on, waiting for the status light to blink then releasing the feed. but this doesn't work.
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
Printer won't stop feeding paper Citizen CT-S651
if its printing ~@{}{@@ZXXCZ wierd things then its a driver problem and you need to reload it
Oct 11, 2013 | Citizen CT-S300 Printer
Ct-s300 printer is printing a blank spot down the receipt
Sounds like the heating element is covered or broken in that spot.
Feb 14, 2013 | Citizen CT-S300 Printer
After installing security updates for xp sp2 the print is hazy
try updating the printer drivers, you can usually find them on the printers website
Oct 08, 2012 | CITIZEN POS CT-S300-RF120AN-CW
Paper keeps feeding after the print of the page
First I would look carefully at the site you are printing from, some will not let you select pages to print.
somesites will have "printer friendly" that you should select otherwise you print ever page fir that website.
next see if you can view PDF before printing then select only the ones you want.
in conclusion the problem appears to be not with your printer but the web pages
Aug 08, 2012 | Citizen CT-S300 Printer
Printer only printing on part of paper When I changed the tape, only the left third of the receipt printed
check your paper rollerand gear first, it is attached to the paper cover. if the roller and gear is good condition your thermal printer maybe bad or dirty. you can try cleaning the thermal head. get a piece of thermal paper fold it. rob the paper on to the thermal head. do it 2 or 3 times with a clean piece of paper. then try printing again. if if doesn't work. call (775)358-2922 look for randy and maybe we cal help. thanks
Sep 17, 2011 | VeriFone VX510
Error light will not stop blinking on my receipt printer; CT-S300. No manual so do not know any troubleshooting techniques. Help?
Hello
This is the direct link to the manual:
http://www.citizen-systems.com/support/downloads/CT-S300UM5_201.pdf
You will probably find what you need inside
Jun 27, 2009 | Office Equipment & Supplies
EPSON m129h pos PRINTER -- NOT EJECTING AND TEARING RECEIPTS
Finally used the hardware trouble shooter in my POS software program. Disconnected all the connections to the printer, shut down the program and workstation. Plugged things back in and YEAH!
Jan 14, 2009 | Epson C31C412144 Thermal Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Citizen CT-S300 Printer Logo
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
