Question about GE JB705TTCC Electric Ran Freestandin 30 inch Wide - 1 Ovens - 5
My GE range is only 10 months old and has rust spots forming on the inside bottom, what causes this? This is also the second GE range to do this in the last 4 years. Are GE ranges known for this?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Rust spots will only occur after the finish is damaged or just simply fail.
This is not common for GE or other manufacturers. But I would not be surprised in the quality of workmanship is slipping for all manufacturers.
Posted on Oct 20, 2013
4 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Posted on Oct 14, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
  • 385 Answers
SOURCE: The oven will not light.. ge xl44 range/oven 10
More than likely you have a bad oven ignitor. It's not uncommon that they need repalced, they do go bad.
Posted on Mar 13, 2011
Rust in barrel
Clean area of rust and sand edges of enamel around spot. Apply rust reformer to area, and when dry, apply a coat of J-B weld to overlap the edges. Auto parts stores have these items, about $10 total.
Nov 29, 2013 | Kenmore 62602 Electric Dryer
Brita profile
yes replace the seal, this type of spotting that forms as rust color occurs on "ferritic" stainless steel. Simply put there exists iron in the alloy and the surface needs to be pacified. Use DeBruce Polish to correct the problem. Non-toxic and odor-less containing NO ACID, this TRUE MULTI-SURFACE CLEANER is the best product for stainless steel AND glass/ceramic cook tops. Go to debrucepolish.com, you will be glad you did!
Aug 26, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
Rust appearing on 10 month old refridgerator doors
How can I put this nicely.
TAKE IT BACK!!!!!! First moisture is forming where it shouldn't, air leak/door gasket not sealing, and second stainless doesn't rust. If rust is forming than it's of poor quality. More iron in it than steel. Isn't there atleast a one year warranty? Don't wait! Till it's too late. Complain NOW!!!
Oct 30, 2012 | KitchenAid Refrigerators
Anything special i should do when taking my g37x sport out of storage after 5 months.car is in heated garage...
Heated or not, condensation in the upper cylinders may have caused some rust to form on the piston rings and other steel parts. These minute rust particles can be highly abrasive and cause damage.
To minimize this, remove the spark plugs and spray into the holes a small amount of high quality motor oil such as Mobil1 5w-30. Do not replace the spark plugs, then with the ignition disabled, crank the engine for 2 seconds, pause for 5 seconds; crank for 3 seconds pause for 5 seconds; and crank for 5 seconds. This will help pre-lubricate surfaces that have become "dry."
Then replace spark plugs and you are ready to go. Keep speeds below 10 mph if tires have developed flat spots, until they are gently warmed up and rounded out. Drive the car for several hours to flush out any pooled contaminant moisture, acid, or particles, Have the oil and filter changed before they can cause any damage.
Note: Removing the spark plugs is an involved procedure. Do a search on "changing spark plugs on g37" to view the steps.
Mar 01, 2010 | 2009 Infiniti G37
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Bottom of door inside badly rusted - oven works fine
Yes you can paint it.. Begin by removing the rust with either a wire brush or a thick paste product called naval jelly. Then prime the area and finally paint it with appliance paint, abailable in a spray can at most hardware stores in the color of your appliance.
May 26, 2009 | General Electric Microwave Oven
Rust on an Audi TT
Audi give a 10 year anti corrosion warranty.
Take to dealer and get them to look at it. I took a 7 year old A4 down and they repainted the bootlid under warranty.
TL
Jul 16, 2008 | 2008 Audi A6
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
its what we in the business call "refrigerator cancer" they are rusting form the inside out. there is not repairing them and not worth the cost of replacing, you can take them off and spray them you might get a little time outta them. reason it happens is the insulation used years ago was fiberglass and would trap moisture between door and liner, eventually rusting through.. new refrigs are insulated with blown in poly-styrene. they don't hold moisture.
Mar 11, 2008 | Kenmore 94499 Refrigerator
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
GE JB705TTCC Electric Ran Freestandin 30 inch Wide - 1 Ovens - 5 Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
