Question about Car Audio & Video
I am installing a power acoustik pd-718NB. I am also using a clarion 7 band eq and i want to be able to use the eq with the radio. The eq has a main out but the radio doesn't have a main in. All it has is sub out, RR out, RL out,FL out,FR out, rv video out and video out can i still use it or no? Which one would i hook it up to??
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 158 Answers
Connect the front channels out from the radio to the main in on the eq.
Posted on Oct 21, 2013
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: wiring
The B.reny connects up to an ALWAYS on power source in your car, like right to the battery or a terminal in your fuse panel that is always on even if the key is off, and the acc hooks up to a swiched power sourch, like where the original radio was connected, as the acc is called the memory wire. good Luck
Posted on Jun 09, 2007
blueextc3221
  • 15935 Answers
SOURCE: I am trying to install
CLICK HERE for your Owners manual in PDF format
CLICK HERE for your Installation Guide in PDF format
As we agreed in chat - you are going to run your 4 channel amplifier as follows...
Front Channels of amplifier will run left and right independently.
Wire up the left speakers in parallel all + together and all - together.
This will yield a 2 Ohm load.
To the Same with the Right Side speakers - on the FRONT Right channel of the amplifier.
Now you have a 2ohm stereo load on the FRONT channels of your amplifier.
And using the BRIDGED nomenclature on the REAR channels of your amplifier - wire up your 4ohm sub mono.
Here is a crude drawing for a visual
Thanks for using FixYa - a 4 THUMB rating is appreciated.
Posted on Sep 05, 2009
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Install
the eq should have all those connection at the back follow instruction
Mar 29, 2009 | Clarion EQS744 7-Band Car Equalizer
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Clarion eqs746
more info would be nice...
what did you hook it up to?
Mar 23, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
How do i connect an HU JVC KD-AVX1 to a Clarion EQS746?
use the front pre out from yur radio. and fade on your radio all the way to just the front. as if you were trying to only hear music from your front speakers.
Feb 07, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
How can i get my power to my EQ?
What kind of eq is it? First thing I would do is hook up the +12 and GND to the same place the amp is hooked up. I think the eq is having a hard time getting ample current, therefore shutting off all the way when the bass hits. Caps are good, but second battery and battery isolator are far superior.
Dec 06, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
