Question about Contec Medical
My Contec EKG machine has an ERROR Code 001 every time I turn it on and then it powers off Its relatively new, well taken care of and happened after changing the paper it has not been used more than a dozen times and not 6 months old.
AJIN G
  • 6694 Answers
SOURCE: Can a Schiller AT2 ECG paper size ( 8.5 * 11)
hi,
Both machines uses the same dimension paper ( 8.5 * 11 Z fold paper ). You can use the paper in GE MAC 1200 EKG machine.
ok
Posted on Sep 27, 2011
SOURCE: I have EKG machine GE
Rotate the paper so the sensor can find thepaper.
Posted on Nov 15, 2011
JDeRuvo
  • 48 Answers
SOURCE: Error Code 05
Just because you've turned the camera off/on, doesn't mean it's been reset. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to Canon's website and look for firmware updates. Download and install them.
Err 05 is when the internal flash is obstructed or the camera doesn't get an reply that the flash open sucessfuly. That should be covered in warranty if its an faulty "pop up flash." Call Canon at 1-800-OK-Canon or Email them at: https://consumer.usa.canon.com/ir/controller?act=SupportMailerAct&fcategoryid=215&modelid=9430
Talk to them and they will give you a more in depth stuff.
J. DeRuvo
Digital Camera HQ
Posted on Dec 04, 2007
SOURCE: Canon 850 E001 Error
I entered service mode and it fixed itself.
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (the covering of the DC controller) . I simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down...then I hit the power button. It reset the error code and all is OK now.
Posted on Apr 24, 2008
yooperbud
  • 8637 Answers
SOURCE: Error Code E000732-001
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Our brand new Contec ECG 1200 is tracing way to lightly. Can barely read. The unit is registering full charge. Also is not printing patient data. Help!
I copied this from an old question similar to yours:
Ekg machines print on thermal paper, This means that the impression is made by the print head heating the paper. If the print head is not making contact with the paper, you will get a faint tracing or no tracing at all. This needs to be adjust by a technician. Contec is located in China and we are a dealer. If you need their info or want us to look at it for you (for free) simply give us a call
Discount Cardiology
805-484-9985
Jan 16, 2017 | Contec Medical
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 | Medical
Everytime that i do an EKG it states drop ,I replaced the of clips and it still says drop,what can I do to correct this problem
Either one of these is causing the problem:
Battery is dying, or
malfunction.
replace the battery to see if it works, if not, replace it.
Sep 12, 2015 | CMS Contec ECG80A Single-Channel Handheld...
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
New Contec ECG 300EG model no tracings appear on the EKG paper.
Discount Cardiology
805-484-9985
Aug 18, 2012 | Contec Medical
User's manual for a Contec Pulse Oximeter CMS50
Here is a link where you should be able to download the appropriate manual for your product.
http://www.contec-oximeter.com/sdp/499627/4/home-2955239/0/Brochure_Download.html
You did not mention which version of the cms-50 that you own and apparently there are several. But the link includes different versions so you should be able to download what you need.
Hope it helps. Please let me know
Thanks
Apr 22, 2010 | Contec ECG Monitor & pulse oximeter
The printer stop when you request to print out and in auto mode print only seconds time
check to see if the power light goes off when that happens. it sounds like the battery will need to be replaced.
wats@mesasales.com. www.overstockme.com. Jeff Watson
Nov 06, 2009 | Schiller Welch Allyn Cardiovit At 2...
EKG Problem
EKGs provide useful data and can help detect various problems related to heart function. One basic determination that can be made with an EKG is the heart rate, which can be determined by measuring the distance between peaks. Diagnosis of certain medical problems is also possible. For example, in patients with high blood pressure, the amplitude of the QRS complex is significantly increased. The balance of certain chemicals in the body can also be detected by an EKG, since the amplitude of the signals is related to the levels of chemicals in the body. Damage in the heart can also be observed by a deformation in the Q wave. The most useful characteristic of the EKG is its ability to detect and describe arrhythmias, or abnormal heartbeats. EKG machines known as Holter monitors are for these detections. Finally, EKGs can be used to observe obstructions in the arteries. This is typically done by looking for a depressed segment between the S and T waves.
Aug 27, 2008 | Omron Portable Ecg Ekg Handheld Hcg 801...
Medical Logo
95 people viewed this question
Top Contec Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
masud
masud
Are you a Contec Medical Expert? Answer questions, earn points and help others
