Question about RCA RS2650 Shelf System
Very little sound when playing vinyl on turntable
Can someone help to solve the low volume issue when playing vinyl. Cd radio and DVD all work fine fine through the same amp. I do not have a phono point on the back of the amp, so i hooked it up to the Aux... Would this make any difference
Hi Lazman, I don't know specific to the 6250, but I think in general you need a "pre-amp" for a phono to work. They are not that expensive. Cindy
Posted on Sep 29, 2007
Rega planner 3
If the amp does not have a dedicated sockets for a turntable - often marked "phono". Then plugging it into an aux socket won't work. You will need to get a Magnetic Cartridge Pre-amp. The turntable plugs into this and that plugs into your aux socket. If at the present you turn up the volume really loud you might just hear the record playing. That will tell you that the cartridge is OK.
Jul 14, 2013 | Audio Players & Recorders
I have tried too hook up my Gemini XL-500, to a Sony Digital Audio DTS discrete 6ch Amp , but get very low volume, tuner & cd dvd, volume is fine, does this have anything to do with the ground?...
No! The amp must have a magnetic cartridge pre-amp to increase the sound level. If it has one it will say "phono" on the inputs on the back and have a "turntable" - or "Phono" selector switch. If it doesn't have one (many new surround amps don't) you won't be able to play it properly untill you get a "magnetic cartridge pre-amp". This will make the signal loud enough to be used on a normal aux imput of the Sony.
Jul 16, 2010 | Gemini XL-500 Turntable
Phono plays lower in volume than cd and tuner. Sounds ok i guess but is about a quarter to one third lower in volume. Is this normal ? Can I plug phono into cd jacks to check if any better ?
Hello. As per the post before me, if you have a receiver with a Phono input(many receivers don't have one anymore) the output of a phono cartridge is around 30 millivolts, vs 300 millivolts for a CD(10 times the amount) or any other line level device. A Phono preamp, also has RIAA(recording engineering standards)Equalization that provides the proper equalization for a Phono cartridge. As per the other post, yes, it will sound very low, and unnatural sounding. If the input you are plugging the turntable input into, doesn't say Phono, you can purchase an inexpensive Phono preamp made just for this very issue. You can try Radio Shack, or find something of better quality on the Internet.
Jan 11, 2010 | Pioneer VSX-453 Receiver
Low Sound from Kenwood Record Player when Hooked up to Amp
Make sure the player is grounded to the amp chassis. Use the ground side of the AM antenna. Use the phono input of the amp, not a tape, CD, or DVD. The signal from a record player is much lower, hence, if you use the phono input for a tape player it is noisy and loud. Clean the needle too. I hope this solves the issue.
Aug 23, 2009 | Onkyo HT-S4100 Theater System
Old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
Aug 04, 2009 | Audio Players & Recorders
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
Play phono - vinyl records
You need to purchase a phono preamp (about $20) and then the output of the preamp can be connected to any line level input on the receiver (tape, CD, DVD etc.)
Feb 25, 2009 | Denon AVR-1602 Receiver
I just hooked up my old amplifier to my turntable and started playing some vinyl. I'm getting an incredibly annoying static sound through the headphones I'm listening through, and I'm positive it's not the...
Make sure the ground wire from the turntable (they all have one) is grounded to the amp, also the turntable has to be connected to the phono input on the amp. Turntable cant connect to cd or aux. Only phono. Also check to see if there is dust and dirt built up on the needle. clean if needed. most likely a grounding issue
Dec 05, 2008 | Audio Players & Recorders
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
RCA RS2650 Shelf System Logo
81 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
