Question about Black & Decker Scroll Jig Saw Blade
Black and decker KS631 jig saw. Whenever I start using this jigsaw, the blade starts cutting and then it gets pulled out by the material being cut. The blades are the quick connect ones where you pull a lever up, insert the blade and via the spring loaded lever, it moves back into position holding the blade. Any help would be good as this is so frustrating when you only get to cut 1mm before the blade comes out!!! Thanks
efs_perpends
  • 1996 Answers
SOURCE: my husband has a BLACK & DECKER JS515 VARIABLE
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Posted on Mar 28, 2009
rowdy45176
  • 2176 Answers
SOURCE: How do I change the blade on a Black & Decker
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Posted on Oct 10, 2009
  • 8404 Answers
SOURCE: Black and Decker JS305 blades come out. The only
I'm thinking the blades that go in Jig Saws are and have been standard since the late 80's. Once upon a time, blades were held on with a collar and a set screw while today they have a fat part that locks into the collet.
Can't find the proper blade at the Depot, my advice would be check with Black and Decker directly.
When I searched B&D, the first hits were Sears (Maybe at K-mart) and Lowes. Home Depot didn't come up at the top. You might find the blades you need at your local Ace or Sentry or Tru-Value or other brand hardware store. Be nice to support your local merchant, your neighbor.
Anyway, try here for your parts http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1496.2514.1020.147
I hope you find this information fruitful
Thanks for your interest in FixYa.com
please vote
positive comments always welcomed
thanks
a
Posted on Dec 06, 2009
  • 6 Answers
SOURCE: I have a corded Black and Decker jigsaw, that is
Don't bother. Return it to the store where it was purchased. No tool should malfunction that early in its life.
Posted on May 26, 2010
heatman101
  • 43501 Answers
SOURCE: I have a JS660 jigsaw.
That is a common problem with those saws... the blade holder is a POS....
Some engineer's idea of a better idea that don't work in the real world...
Here is another review of that saw...
http://www.epinions.com/review/Black_Decker_JS660_Jigsaw_with_Smart_Select_Dial/content_493711167108
Don't know what else to tell you except that you may have to use a different saw....
I usually use my Milwaukee Sawzall for that job....I can place a longer blade in that and it works much better then a jig saw...
I have even used the old hacksaw standby already in a tight space...the bolts are brass and if you can get a groove halfway through you can break the top off from there...
heatman101
Posted on Mar 23, 2011
What models of jigsaw blades are suitable for cutting wood using a Black & Decker DN31-H1 Jigsaw?
Blade can be had at any hardware store or home improvement store. There are a lot of wood cutting blades available depending on the hardness of the wood and how thick the material is
Nov 06, 2014 | Saws
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
My Black&Decker jigsaw loses power when cutting material
Ensure that blades are sharp, the material you are cutting is not greater than the rating of the saw.
Jan 18, 2011 | Saws
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
When I try to cut with my saw, the blade bends so that the cut is at an angle. Because of this angle cut, it is difficult to follow a line but even if I can follow the line, the angle cut through a 3/4...
This is a common issue with jig saws. There are sometimes larger blades, but all seem to distort to some degree. The only real solution is to go slow enough to allow the blade to return to it's normal shape...Essentially, is sounds like another tool would work better, but often you are scrolling with a jig saw and circular saw (for example) would not work.
The other workaround involves several cuts, so the final cut is removing much less material.
Nov 07, 2010 | Black & Decker Black decker Firestorm...
I have a corded Black and Decker jigsaw, that is brand new. It cut one cut and then will not come back on. Can i reset something on the saw?
May 26, 2010 | Black & Decker Single Speed Jig Saw
Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
I do not know to use the black and decker jigsaw.
Draw the circle pattern on the wood where you need it. Drill a 1/2 or 3/8 inch hole inside the circle, near the circle line. Insert the jigsaw blade into the hole and start cutting, following the line.
If you have the scrolling feature on your saw, don't use it, lock the scroll.
Sep 20, 2009 | Black & Decker Saws
Black & Decker Scroll Jig Saw Blade Logo
121 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
