Question about Apex Computer Technology (TM-302-3) Micro ATX Mid-Tower Case
How to remove the side panel - Apex Computer Technology (TM-302-3) Micro ATX Mid-Tower Case
  • 4 Answers
Hey bro one side is small one is big so u take out the side that is small bro after take out the side that the fan on it
Posted on Oct 20, 2013
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
How to replace evapotator coil
in a word, alldata.com
why would you think its bad. it leaks?????????????
why not ask for diagnosis help if it dont leak.
(why do the hardest job first?)_?
ok,
  1. Properly disarm the airbag system. Refer to the disarming procedure for additional information.
  2. If equipped with a navigation system, remove the right-hand lower B-pillar trim panel and right-hand rear quarter trim panel.
  3. Remove the front floor console.
  4. Remove the transmission selector lever.
  5. Remove the windshield side garnish moldings and cowl panels.
  6. Remove the steering column cover.
  7. Remove the left-hand instrument panel side finish panel.
  8. Disconnect the bulkhead electrical connector.
  9. Remove the parking brake release handle screws.
  10. Disconnect any remaining electrical connectors from the under the left side instrument panel.
  11. Remove the steering column pinch bolt.
  12. To avoid damage to the clockspring, do not allow the steering column shaft to rotate while the intermediate shaft is disconnected.
  13. Remove the instrument panel center braces.
  14. From under the right side of the instrument panel, disconnect the bulkhead electrical connector, ground strap bolt and any remaining electrical connectors.
  15. Remove the cowl panel grille to access an instrument panel mounting bolt. Remove the bolt.
  16. Remove the instrument panel defroster grille.
    WARNING To avoid damaging the sun load sensor electrical connector, remove the grille just enough to remove the connector.
  17. Remove the remaining top mounting bolts that were under the defroster grille.
  18. Disconnect the antenna cable lead.
  19. Remove the right-hand instrument panel side finish panel.
  20. Remove the ground strap bolt below the center console section.
  21. If equipped with a navigation system, disconnect the global positioning system (GPS) antenna.
  22. If equipped with a navigation system, disconnect the audio unit amplifier connectors and position the wiring harness so that it can be removed with the instrument panel.
  23. Remove the right and left side instrument panel mounting bolts.
  24. Disconnect the in-vehicle air temperature hose and remove the instrument panel.
  25. Installation is the reverse order of removal. Tighten the instrument panel mounting bolts to 22 ft. lbs. (30 Nm).
Jul 07, 2014 | 2004 Lincoln Aviator
How do i remove the rear freezer panel
Remove all the contents from the freezer. Next is remove the the shelves of the freezer by lifting the front of the shelf and then pulling the shelf out of the freezer. Remove screws on the left and right side of the curved panel, located on the bottom of the back panel. Remove the curved panel.
Lift the bottom of the air tower cover, located in the center of the freezer's back panel, straight back and pull the air tower cover down to remove it. Remove the screw from the left side of the evaporator fan opening and from the panel in the upper-left side of the freezer's back panel and pull the back panel toward you and out of the freezer.
Sep 28, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Removing front panel on DX4860 UR11P
First remove the side panel so that you can see the catches that hold the front panel to the metal frame. There might be a screw or two on the back of the computer that holds the side panel that you will have to remove. Most newer model computers will only allow the removal of one side panel. Once you remove the side panel look inside towards the front near where the side panel was and you will see plastic catches that hold the front panel to the metal frame. Push the Plastic catches so that they will release the front panel.
May 30, 2012 | Gateway Computers & Internet
This maybe a dumb question but can anyone help me by telling me were it is i can find the computer on a 2001 ford focus please and thank you
Hi, the PCM is hid inside the car behind the kick panel on the passenger's side.
Removal & Installation
  1. Disconnect the battery ground cable.
  2. Remove the instrument panel side trim strip.
  3. Remove the cowl side trim panel (kick panel).
  4. Remove the glove box.
  5. Remove the passenger side lower foot well trim panel.
  6. Remove the two retaining nuts.
  7. Remove the generic electronic module (GEM0 and the bracket and position aside.
  8. Disconnect the 3 powertrain control (PCM) module electrical connectors and remove the PCM.
  9. Installation is the reverse of the remove procedure.
    CAUTION Make sure that the PCM electrical connectors do not unlock when installing the GEM module.
Aug 29, 2011 | 2001 Ford Focus
Hi I,ve got a 2000 Jeep Grand Cherokee, the problem I,m having is when I turn on the heating fan i get a mist or steam coming out of the vents smells like coolant could this be a heater core problem ,...
Yes, your core is leaking. The core is in the box under the dash. The procedure is quite involved. I will attempt to paste from autozone.com below:
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Disconnect and remove the negative battery.
    CAUTION After disconnecting the negative battery cable, wait 2 minutes for the driver-s/passenger-s air bag system capacitor to discharge before attempting to do any work around the steering column or instrument.
  3. Drain the cooling system into a clean container for reuse.
  4. Remove the instrument panel by performing the following procedure:
    1. Turn the steering wheel in the straight-ahead position.
    2. Remove the A-pillar trim from both sides of the vehicle.
    3. Remove the top cover from the instrument panel.
    4. Near the windshield line, remove the 4 instrument panel-to-chassis nuts.
    5. Remove the scuff plates from both front door sills.
    6. Remove the trim panels from both sides of the inner cowl.
    7. Remove the floor console.
    8. Remove the fuse cover from the junction box.
    9. Remove the instrument panel cluster bezel.
    10. Remove the steering column opening cover from the instrument panel.
    11. Remove the steering column bracket from the instrument panel column support bracket.
    12. Remove the lower steering column shroud cover-to-multifunction switch screw; then, unsnap both halves of the shroud cover from the steering column.
    13. Disconnect the instrument panel wiring harness connectors from the following steering column components:
      Both lower clock spring connector receptacles Left multifunction switch receptacle Right multifunction switch receptacle Both ignition switch receptacles Shifter interlock solenoid receptacle Sentry Key Immobilizer Module (SKIM) receptacle, if equipped
    14. Turn the ignition switch to ON position; then, release and remove the shifter interlock cable connector from the ignition lock housing receptacle.
    15. Turn the ignition switch to OFF position; this will prevent the steering wheel from turning and the loss of the clock spring centering following steering column removal.
    16. Remove the 4 steering column-to-instrument panel steering column bracket nuts.
    17. Remove the steering column from the instrument panel.
    18. Disconnect both side body wiring harness bulkhead connectors, the Ignition Off Draw (IOD) wiring harness connector and the fused wiring harness connector from the junction block connector receptacles.
    19. Disconnect the instrument panel wiring harness-to-floor console component connectors:
      Air bag control module connector receptacle Parking brake switch terminal Transmission shifter connector receptacle
    20. Remove the 2 instrument panel wiring harness-to-floor console ground terminals located behind the air bag control module.
    21. Disconnect the instrument panel wiring harness-to-floor console retainers.
    22. Remove the instrument panel-to-floor console bracket screws and the bracket.
    23. Remove the driver-s side floor duct-to-heater/air conditioning housing assembly screw and remove the duct.
    24. If equipped with a manual heating-air conditioning system, disconnect the vacuum harness connector from behind the driver-s side floor duct.
    25. Remove the instrument panel steering column support bracket-to-driver-s side of the heater/air conditioning housing assembly screw
    26. Remove the instrument panel steering column support bracket-to-intermediate bracket screw.
    27. Remove the instrument panel steering column support bracket-to-driver-s side cowl plenum panel nut.
    28. Remove the 2 instrument panel-to-driver-s side cowl side inner panel screws.
    29. Remove the instrument panel end cap.
    30. Remove the lower right center bezel from the instrument panel.
    31. At the passenger-s side cowl side inner panel, disconnect the instrument panel wiring harness bulkhead connector from the lower cavity of the inline connector.
    32. Near the right side cowl inner panel, located under the end of the instrument panel, disconnect both halves of the radio antenna coaxial cable connector.
    33. Disconnect the 2 instrument panel-to-heater/air conditioning assembly wiring harness connectors.
    34. At the passenger-s side, remove the 2 instrument panel structural duct-to-heater/air conditioning housing assembly screws.
    35. At the passenger-s side cowl side inner panel, remove the 2 instrument panel-to-passenger-s side cowl side inner panel screws.
    36. With the help of an assistant, lift the instrument panel from the vehicle.
  5. Discharge and recover the air conditioning system refrigerant.
  6. Disconnect the air conditioning system lines at the evaporator. Plug the openings to prevent contamination.
  7. Disconnect the heater hoses from the heater core. Plug the openings to prevent coolant loss.
  8. If equipped with a manual temperature control system, unplug the heater/air conditioning system vacuum supply line connector from the T-fitting located near the heater core tubes.
  9. From the passenger-s side inner fender shield, remove the coolant reservoir/overflow bottle.
  10. From the passenger-s side in the engine compartment dash panel, remove the PCM; DO NOT unplug it, just move it aside.
  11. In the engine compartment, remove the heater/air conditioning housing-to-chassis nuts.
  12. At the center of the dashboard, remove the rear floor ducts from the floor heat duct outlets.
  13. Disconnect the heater/air conditioning housing wire harness connectors.
  14. In the passenger compartment, remove the heater/air conditioning housing-to-chassis nuts.
  15. Place covers inside the vehicle to catch any spilt coolant.
  16. Remove the heater/air conditioning housing assembly from the vehicle.
  17. Remove the foam gasket from around the heater core tubes.
    NOTE Note the position of the irregular shaped gasket so that it may be reinstalled in its correct position.
  18. Remove the heater core retainers and screws.
  19. If necessary, remove the mode door actuator for clearance to remove the core.
  20. Remove the heater core from the heater/air conditioning housing assembly.
    Fig. View of the instrument panel assembly-Grand Cherokee
Sep 16, 2010 | 2000 Jeep Grand Cherokee
How to change heater core on 2005 dodge stratus?
  1. Disconnect the negative battery cable.
  2. Remove the radio/HVAC control module bezel. CAUTION
    The vehicles covered by this manual are equipped with a Supplemental Restraint System (SRS), which uses air bags. Whenever working near any of the SRS components, such as the impact sensors, air bag modules, steering column and instrument panel, disable the SRS, as described earlier in this section.
  3. Remove the right instrument panel side trim.
  4. Remove the two retaining screws at the lower right side support beam.
  5. Remove the instrument panel support bolt at the A-pillar.
  6. Remove the left instrument panel side trim and upper instrument panel bezel.
  7. Remove the lower knee bolster and console screws at the instrument panel.
  8. Remove the gearshift knob and shifter bezel.
  9. Remove the mounting screws at the front and rear of the floor console. Remove the front and rear console halves.
  10. Remove the right side instrument panel support strut.
  11. Drain the cooling system into a suitable container, then disconnect the heater hoses at the cowl panel. Plug the heater core outlets to prevent coolant from spilling during unit housing removal.
  12. Remove the mounting screws and heater core cover.
  13. Remove the heater core from the vehicle. To install:
  14. Carefully position the heater core unit into the heater housing.
  15. Install the heater core cover onto the heater housing and tighten the mounting screws.
  16. Install the right side instrument panel support strut.
  17. Install the front and rear console halves.
  18. Install the shifter bezel and gearshift knob.
  19. Install the lower knee bolster and console screws at the instrument panel.
  20. Install the upper instrument panel bezel and left instrument panel side trim.
  21. Install the instrument panel support bolt at the A-pillar.
  22. Install the two retaining screws at the lower right side support beam.
  23. Install the right instrument panel side trim.
  24. Install the radio/HVAC control module bezel.
  25. Fill the cooling system to the proper level.
  26. Connect the negative battery cable.
Aug 13, 2010 | 2005 Dodge Stratus
Need to remove dashboard 1992 ford aerostar
Check this procedure...
  2. Detach the wiring connector from the instrument panel, located in the engine compartment, by loosening the bolt and separating the connector halves.
  3. Remove the left and right windshield inside mouldings.
  4. Remove the defroster grille.
  5. Remove the glove compartment door finish panel.
  6. Remove the instrument panel steering column cover.
  7. Remove the four bolts attaching the steering column lower reinforcement. Remove the reinforcement.
  8. Remove the right and left cowl side panels.
  9. Remove the two nuts retaining the hood latch control handle and cable assembly to the left cowl side. Remove the control handle and cable assembly, then reinstall the nuts to hold the bracket and relay in place.
  10. Detach the wiring on the left cowl side panel and, if equipped, the vacuum hose harness connector. The number and location of the connectors may vary depending on optional equipment.
  11. Detach the brake light switch wiring connector. Detach the clutch pedal position switch on manual transmission equipped vehicles.
  12. Remove the steering column-to-extension shaft pinch bolt. Compress the extension shaft toward the engine, then separate from the column U-joint.
  13. Detach the transmission control selector indicator from the steering column.
  14. Disconnect the wiring from the windshield wiper intermittent control module and, if equipped, the wiring from the low oil level relay. Both are located to the right of the steering column.
  15. Disconnect the radio antenna lead-in cable at the right cowl side panel.
  16. Disconnect the heater temperature cable. If equipped, detach the vacuum hose harness connector.
  17. Remove the five screws attaching the top of the instrument panel to the cowl side top panel.
  18. Remove the one nut attaching the lower right side of the instrument panel to the cowl side panel.
  19. Remove the two rearward nuts, then loosen the two forward nuts located to the right of the steering column, attaching the instrument panel to the center mounting bracket.
The following removal steps require the help of an assistant.
  1. Support the instrument panel. Remove the three bolts and one nut attaching the instrument panel to the left cowl side panel.
  2. Carefully pull the instrument panel rearward, then disconnect any remaining wires or other components.
  3. Carefully remove the instrument panel through the left front door.
  4. If replacing the instrument panel, transfer all the components to the replacement instrument panel.
continue...
Jun 29, 2010 | 1992 Ford Aerostar Extended
How i revome the stereo on my chevy malibu 2006
Disconnect the negative battery terminal
to prevent an accidental short
circuit.
Unclip and remove wood grain/painted
trim pieces from both sides of
steering wheel. (Figure A)
Unclip and remove side panel from
driver’s side of dash with door open
and remove (2) 7 MM screws.
(Figure B)
Remove (2) 7 MM screws from bottom
edge of panel below steering
wheel, unclip panel and let hang. It
is not necessary to completely
remove panel. (Figure C)
grain/painted trim piece from above
glove box.
passenger side of dash with door
open and remove (2) 7 MM screws
from behind panel
of glove box then open box and
squeeze sides together to open further
and remove the remaining (4)
7MM screws. Unclip the black vent
cover under the glove box then unclip
and remove entire glove box assembly.
(Figure F)
7
Unclip and remove trim panel surrounding
radio and climate controls.
(Figure G)
8
Remove (4) 7 MM screws securing
the radio and (2) 7 MM screws securing
the climate control. Unplug and
remove the radio. (Figure H
Feb 08, 2010 | Sony Car Audio & Video
Need help with dash removal.
  1. Remove the A-pillar and cowl side Trim Panels
  2. Remove the front floor console.
  3. Depower the supplemental restraint system (SRS).
  4. Remove the instrument panel side finish panels.
  5. Remove the 2 steering column opening cover screws.
  6. Remove the steering column opening cover.
  7. Remove the 3 lower steering column cover screws.
  8. Remove the lower steering column cover.
  9. Disconnect the steering column electrical connectors.
  10. Disconnect the RH side bulkhead electrical connector.
  11. Disconnect the RH side body harness electrical connector.
  12. Remove the 2 parking brake release handle screws.
  13. Disconnect the LH side instrument panel electrical connectors.
  14. CAUTION: To avoid damage to the clockspring, do not allow the steering column shaft to rotate while the intermediate shaft is disconnected.
  15. Remove the pinch bolt..
  16. Disconnect the adjustable pedal electrical connector.
  17. Disconnect the brake light switch electrical connector.
  18. Remove the 2 LH instrument panel center brace bolts..
  19. Remove the 2 LH instrument panel center brace nuts.
  20. Remove the LH instrument panel center brace.
  21. Disconnect the transmission range selector lever cable.
  22. Disconnect the RH side bulkhead electrical connector.
  23. Disconnect the LH side body harness electrical connector.
  24. Remove the 3 ground strap bolts.
  25. Disconnect the inertia switch electrical connector.
  26. Disconnect the RH side instrument panel electrical connectors.
  27. Remove the 2 RH instrument panel center brace bolts.
  28. Disconnect the vacuum connector.
  29. Remove the 2 RH instrument panel center brace nuts.
  30. Remove the RH instrument panel center brace.
  31. Remove the cowl panel grille
  32. Remove the instrument panel bolt located under the cowl panel grille
  33. Remove the instrument panel defroster grille.
  34. CAUTION: To avoid damage to the sunload sensor and electrical connector, remove the grille just enough to disconnect the connector.
  35. Disconnect the sunload sensor electrical connector.
  36. Remove the 2 instrument panel top cowl bolts.
  37. Disconnect the antenna lead-in cable.
  38. Disconnect the RCM electrical connector.
  39. Disconnect the center ground strap bolt.
  40. CAUTION:To avoid damage to the instrument panel, an assistant is required to support the panel before carrying out this step.
      • Before removing the instrument panel make sure all electrical connector wiring is free and not hindered.
  41. Remove the 4 instrument panel bolts.
  42. Remove the instrument panel.
  43. To install, reverse the removal procedure.
Feb 11, 2009 | 2005 Ford Explorer
Apex Computer Technology (TM-302-3) Micro ATX Mid-Tower Case Logo
60 people viewed this question
Top Apex Computers & Internet Experts
David Payne
David Payne
Are you an Apex Computer and Internet Expert? Answer questions, earn points and help others
